[SUGGESTION] Open Source Home Automation
First off let me state that I know that there is a "suggestions" forum, but I felt this was more appropriate for the General Discussion to get more feedback.
I have always had a passing interest in home automation, but have never actually gotten to the practical application phase. After finding out about the Propellor about 2 years ago it dawned on me that the Propellor might be an excellent starting point for an open source home automation solution.
If you are currently, have in the past, or plan to in the future build home automation solutions based on the Propeller -- please give some feedback. I feel that this niche market could turn in to a nice product demand source for both Parallax and for third-party hardware developers while still retaining the open source vibe.
Thoughts?
Thoughts?
The introduction to chapter 11 of Programming and Customizing the Multicore Propeller says "we will explore a Propeller-powered HVAC (heating, ventilation, air conditioning) energy-saving 'green' house model." The chapter explains how to use the Propeller to open and close air duct opening to control the temperature of individual rooms within a building (it uses a model for illustration purposes).
I've been thinking of doing something similar in our home. As it is now, there is just a single thermostat to control the heat pump. Often one area of the house is colder than desired while other areas are warmer than desired. I figure if I add a temperature sensor to each room in the house and motorize the louvers of the air vents, I could better control the temperature of the rooms and even personalize the temperature based on the primary occupant's preference. I think having control of the temperature of each room could save money on the power bill since I could leave infrequently occupied rooms a bit warmer than the rooms which are frequently used.
I'm planning on using Nordic nRF24L01+ transceivers for communication between the various Propeller boards. These transceivers are so inexpensive ($1.30 each when you buy ten at a time) they don't add much to cost of a control boards.
I experimented with multiple Nordic transceivers in my panic button project. I gave each Propeller board its own ID number. The boards used this ID number to determine when it was their turn to transmit information. This kept the boards from interfering with each other when it came time to transmit data.
I recently replaced our original sprinkler control box with my own Propeller-powered version. I figure I'll add a transceiver to it so I can monitor room temperature and sprinkler system settings from some sort of base station. I'll probably have control stations in several rooms in the house (bedroom, kitchen and living room)
I made my own control board for our kitchen oven (the original stopped working) so I could add a transceiver to it. With the oven included in the system, I could start preheating the oven without getting up from the couch. Think of how many more ways it would be possible to be lazy with such a system.
I also have plans to add a burglar alarm, and water leak detector (in the basement) to this system (this system is currently vaporware). I haven't done much with the Spinneret yet but I'd want to be able to access this system from the internet so I'll need to join NWCCTV in exploring the internet options.
If/when I ever join the smartphone crowd, I'll want to add some sort of interface for the phone. If I continue using my dumbphone, I could still use a cell phone to interface with the system by using one of Tubular's Telit boards.
I'd also like to include other "normal" home automation tasks (like lighting) to this (presently vaporware) system.
I'll need to figure out a way to include our cloths iron in this system so I'll never need to worry about the question "Did we leave the iron on?" as we are just getting on the freeway for a weekend trip.
I second Franklin's request:
The current categories are:
Access - cards, fobs, car remotes, finger print scanners, electric strikes for entry.
Security - Door contacts, window contacts, pir sensors, glass break monitors, dual mode (pir/microwave, pir/sound).
Lighting - Motion sensors, switches, schedules.
HVAC - Max comfort for min energy use. Multiple temp settings based on time & occupancy. Multiple zones. Automated blinds and shutters.
I am a programmer by trade, and a green novice when it comes to building electronics. So far my skills are limited to working with the PEK and PPDB. Along the way I have assisted some LEDs and capacitors in releasing the magic smoke. It is amazing how much longer LEDs run when you grasp the concept of a current-limiting resistor!
So I am hoping to tap in to the vast amount of knowledge that I have seen on these forum over the last 2+ years. I have that I learn best when I have a project that grabs my interest. I am hoping that home automation can be that project.
Oh yes, part of the "Internet access" category (which I forgot in the previous post). Password protection, encryption, VPN, antivirus.
Not sure antivirus is necessary if a prop is used. Any propeller viruses (viri?) out there?
The OpenBeacon project uses Nordic nRF24L01+ transceivers. They use XXTEA for the encryption algorithm since it doesn't require much RAM. I don't know enough about XXTEA and other encryption techniques to know if RAM usage should be a major concern when using encryption on the Propeller.
I'm planning on using some sort of encryption myself but I (presently) don't know enough about the various encryption techniques to make an informed decision about which technique to use.
Edit: Obviously I was thinking about the security of the wireless component of the system.
I want to give a heads up to OpenHAB http://openhab.org/index.php/start/
This is a java based open source automation server with "binding"-components to interface with almost any
house automation protocol like knx, asterisk, z-wave and 38 others including TCP/IP, UDP, serial etc.
There is also a rasperry pi version.
I know your main target is to do it all with the propeller. But if there are components you just pull from the shelf
and are very flexible to configure why spending time on developing something on your own?
Here is a demo-server
http://demo.openhab.org:8080/openhab.app?sitemap=demo
you can control in your browser
or with this android-app
https://play.google.com/store/apps/details?id=org.openhab.habdroid
download runtime-modul
https://openhab.googlecode.com/files/openhab-runtime-1.3.1.zip
Zip-file containing the binding modules
https://openhab.googlecode.com/files/openhab-addons-1.3.1.zip
Editor for configuration files
https://openhab.googlecode.com/files/openhab-designer-win-1.3.1.zip
configuration files for a local demo
https://openhab.googlecode.com/files/openhab-demo-configuration-1.3.1.zip
documentation is still quite rudimentary but there are several support offers
attached the configuration files I used for a small test demo
the difference to the standard demo is just an item
and some additional rules
[/URL]
best regards
Stefan
Thank you for sharing this! I don't have any problems with a mixed technology solution. Your proof of concept with the Propeller as a component is certainly enough to show that it can be done and the Propeller can be a part of the solution.
