DEMO: Succesive Aproximation Normalization (SAN) Filter — Parallax Forums
Beau SchwabeBeau Schwabe Posts: 6,575
edited 2013-11-24 15:32 in Propeller 1
This is just a cool little code snip-it I wanted to pass along. Although written for the Propeller, it could easily be adapted to a Basic Stamp.
Purpose:
Take a data value where you know the upper and lower limits and
"normalize" the data so that it proportionally scales to a binary
weighted value.
For instance, say you have a potentiometer that reads 204 on one extreme
and 8453 on the other extreme. ...And the current value is 2834.
You want to scale that to a 12-Bit number? Simply load the Data,
BitResolution, RefLOW, RefHIGH variables and call the function. The
returned value will contain the result. 1306 in this case.
Yes, you could apply the formula ...
Data = [(Data-RefLOW)/(RefHIGH-RefLOW)]*(2^BitResolution)
... but the SAN filter avoids any floating point, and gets the job done
using only shift and adds.
enjoy!
OBEX:
http://obex.parallax.com/snippet/699
  • lonesocklonesock Posts: 917
    edited 2013-07-19 12:09
    Nice! Here's a version that is 9 bytes smaller:
    PUB SAN(_Data,_BitResolution,_RefLOW,_RefHIGH):Temp|RefMID
        repeat _BitResolution
          RefMID := (_RefHIGH + _RefLOW) >> 1
          Temp += Temp - (_Data > RefMID)
          if Temp & 1
             _RefLOW := RefMID
          else
             _RefHIGH := RefMID
    Of course this will still be slower than the equation form, but to use that you need to reorder so you do the multiplication (via SHL), then the division, and of course make sure the intermediate values don't overflow. A PASM version of this function would be a clear winner.
    thanks,
    Jonathan
  • Beau SchwabeBeau Schwabe Posts: 6,575
    edited 2013-07-19 12:54
    lonesock,
    Thanks... I added and Assembly option to the OBEX file ... version 1.1
    '------------------------------------------ Allocate Variables in SPIN
    VAR
    long    Data,BitResolution,RefLOW,RefHIGH
    '------------------------------------------ Call Assembly routine from some PUB
    PUB DEMO
            cognew(@PASM,@Data)
    '------------------------------------------ Main Assembly program
    DAT
                  org
    '------------------------------------------ Get Variables
    PASM          mov       pTemp,par
                  rdlong    pData,pTemp
                  add       pTemp,#4
                  rdlong    pResolution,pTemp
                  add       pTemp,#4
                  rdlong    pRefLOW,pTemp
                  add       pTemp,#4
                  rdlong    pRefHIGH,pTemp
                  add       pTemp,#4
                  mov       pTemp,#0
    '------------------------------------------ Apply Filter
    Loop          mov       pRefMID,  pRefHIGH
                  add       pRefMID,  pRefLOW
                  shr       pRefMID,  #1
                  sub       pRefMID,  pData         wc,nr
             if_c mov       pRefLOW,  pRefMID       'If pData >  pRefMID ; RefLOW  = pRefMID
            if_nc mov       pRefHIGH, pRefMID       'If pData =< pRefMID ; RefHIGH = pRefMID
                  rcl       pTemp,#1
                  djnz      pResolution, #Loop
                  wrlong    pTemp,par
    '------------------------------------------ Exit COG
                  cogid     pTemp
                  cogstop   pTemp
    pData         long      0
    pResolution   long      0
    pRefLOW       long      0
    pRefHIGH      long      0
    pRefMID       long      0
    pTemp         long      0
    edited 2013-07-19 13:18
    'Clever algorithm, Beau!
    edited 2013-07-19 14:41
    Thanks Phil,
    You realize the algorithm is just a classic game of "Pick a number between 1 and 10 in the fewest number of guesses"? ; the only feedback you get is if your guessed number is higher or lower than the actual number. What most people don't realize is that this classic game produces a binary equivalent of the actual number that you are trying to guess if you were to keep track of the HIGH and LOW results when guessing.
    Here is a writeup I did back in March for our local Hacker space:
    edited 2013-07-21 06:35
    Purpose:
    weighted value.
    Thanks Beau, nice and neat. I normally do this with scaled integers but here is your method tested in my Tachyon Forth.
    Just copy and paste all of this to load and run.
    [FONT=courier new]\ Succesive Aproximation Normalization Filter v1.1 - Beau Schwabe
    \ Modified for Tachyon Forth
    \ REGISTER METHOD - uses temp registers for variables
    \ offsets: 0 = high 4 = low 8 = data
    \ Code size = 40 bytes
    \ Execution time = 246us
    DECIMAL HERE        \ use decimal mode and mark code space fo
    pub SAN ( res data low high -- result )
        0 REG ! 4 REG ! 8 REG !
        0 SWAP
        FOR  ( temp )
          2*
          0 REG @ 4 REG @ + 2/        ( temp mid )
          DUP 8 REG @ < IF 4 REG ! 1+ ELSE 0 REG ! THEN
        NEXT
    \ Report code size
    HERE SWAP - CR . ."  bytes "
    \ Run demo and also report execution time
    12 2834 204 8453 NEWCNT SAN .LAP CR ."  Result = " . ( 1306 )
    [/FONT]
    This is the result:
    [FONT=courier new]HERE SWAP - CR . ."  bytes "
    [COLOR=#ff0000]40 bytes  ok[/COLOR]
    12 2834 204 8453 NEWCNT SAN .LAP CR ."  Result = " . ( 1306 )[COLOR=#ff0000] 246us[/COLOR]
    [COLOR=#ff0000] Result = 1306 ok[/COLOR]
    [/FONT]
    BTW, this is the normal named variables method in place of the temporary "registers"
    [FONT=courier new]\ VARIABLES METHOD - 288us 40 bytes
    LONG    data,low,high
    DECIMAL HERE
        high ! low ! data !
        0 SWAP
        FOR  ( temp )
          2*
          high @ low @ + 2/        ( temp mid )
          DUP data @ < IF low ! 1+ ELSE high ! THEN
        NEXT
    12 2834 204 8453 NEWCNT SAN .LAP SPACE . ( 1306 )
    [/FONT]
    edited 2013-07-21 20:07
    I've now added the NORMALIZE word to EXTEND.fth with this improved version.
    [B][COLOR=#000000][FONT=Ubuntu Mono]
    [FONT=courier new]\ [/FONT][/FONT][/COLOR][FONT=courier new][COLOR=#000000][B]Succesive Aproximation Normalization Filter[/B][/COLOR][COLOR=#000000] - Beau Schwabe[/COLOR]
    [COLOR=#000000]\ Modified for Tachyon Forth[/COLOR]
    [COLOR=#000000]\ Code size = 36 bytes[/COLOR]
    [COLOR=#000000]\ Execution time = 206us for 12 bits[/COLOR]
    [/FONT][/B][FONT=courier new][B][COLOR=#000000]\ Use temp registers for variables[/COLOR]
    [COLOR=#000000]\ offsets: 0 = low ;  4 = high[/COLOR]
    [/B][/FONT][B][FONT=courier new] [COLOR=#000000]
    pub [/COLOR][COLOR=#000000][B]NORMALIZE[/B][/COLOR][COLOR=#000000] ( data   bits low high -- result )[/COLOR]
    [COLOR=#000000]    4 REG ! 0 REG !                                \ store low and high to register variables[/COLOR]
    [COLOR=#000000]    0 SWAP                                         \ Init temp[/COLOR]
    [COLOR=#000000]    FOR  ( data temp )                             \ Execute loop for number of bits of resolution[/COLOR]
    [COLOR=#000000]      2*                                           \ temp<<1[/COLOR]
    [COLOR=#000000]      0 REG @ 4 REG @ + 2/    ( data temp mid )    \ calc new mid    [/COLOR]
    [COLOR=#000000]      DUP 4TH >                                    \ Compare mid > data[/COLOR]
    [COLOR=#000000]         IF 4 REG ! ELSE 0 REG ! 1+ THEN           \ Set new low or high and track[/COLOR]
    [COLOR=#000000]    NEXT[/COLOR]
    [COLOR=#000000]    NIP                                            \ discard original data[/COLOR]
    [COLOR=#000000]    ;[/COLOR][/FONT][/B]
    edited 2013-07-22 12:27
    Thanks Peter!.... that's great. I just hope this might prove useful to someone.
  • TubularTubular Posts: 4,768
    edited 2013-07-22 14:16
    Beau this is positively brilliant, and I have an immediate use for it. Thankyou
  • MJBMJB Posts: 1,235
    I stumbled across this in Peters Tachyon Forth EXTEND.fth file ...
    and wondered about the real timings of the different versions of to solve this problem
    so I made some experiments, first in Tachyon then in SPIN.
    For the Tachyon code see this post in the Tachyon thread.
    What is still missing is a straight forward SPIN implementation using the FLOAT library
    which I expect to be really slow.
    Maybe someone can provide the numbers.
    this is the problem we want to solve:
    1) Data = [(Data-RefLOW)/(RefHIGH-RefLOW)]*(2^BitResolution)
    if we rearrange it a little we get rid of the requirement for float immediately
    2) Data = (Data-RefLOW) * (2^BitResolution) / (RefHIGH-RefLOW)
    and then replace the * 2^n with shift left
    3) Data = ((Data-RefLOW) SHL BitResolution) / (RefHIGH-RefLOW)
    I get the following timings: @80MHz
    Beau's filter in PASM 26 us
    Beau's filter in SPIN 579 us ( Peter writes around 1300us in his EXTEND.fth, I don't know how he measured it)
    EQ3 in SPIN 34 us
    from Tachyon
    Beau's filter in TForth 205 us
    EQ2 in a lazy impl. in TF 208 us
    EQ2 fast impl. in TF 28 us
    EQ3 fast TF impl. 24 us
    SPIN FLOAT-LIB ?? the horrible example of NOT to do it ;-)
    PASM impl. of EQ3 ?? would be a great reference
    VAR
    '   Variables must remain in this order for both optons
    long    Data,BitResolution,RefLOW,RefHIGH,Data2,ResSpin,ResMJB,Resasm,Ressimple,Tasm,Tspin,Tsimple
    PUB DEMO
        PST.Start(230400{<- Baud})
        BitResolution := 12
        RefLOW := 204
        RefHIGH := 8453
        Data := 2834
        'Assembly Version
        Tasm := cnt
        Filter.Asm(@Data)
        Tasm := (cnt - Tasm) / 80        ' us
        Data2 := 2834
        Tspin := cnt
        ResSpin := Filter.Spin(Data2,BitResolution,RefLOW,RefHIGH)     'Spin Version
        Tspin := (cnt - Tspin) / 80        ' us
        Tsimple := cnt
        ' ResMJB := SARMJB(Data2,BitResolution,RefLOW,RefHIGH)
        ResMJB := ((Data2 - RefLOW) << BitResolution  )   / (RefHIGH - RefLOW)  ' direct SPIN version
        Tsimple := (cnt - Tsimple) / 80
         repeat
            PST.dec(Data)       ' from PASM
            PST.Char(9)
            PST.dec(Tasm)
            PST.Char(9)
            PST.dec(ResSpin)
            PST.Char(9)
            PST.dec(Tspin)
            PST.Char(9)
            PST.dec(ResMJB)
            PST.Char(9)
            PST.dec(Tsimple)
            PST.Char(13)
            ' PST.Char(10)
    DAT  { result is                value   time in us
            Filter.Asm(@Data)    1306    26
            Filter.Spin                1306    579
            direct SPIN              1305    34
