Propeller PBD Schematic Error
Alexander (Sandy) Hapgood
On page 4 of the Propeller PBD schematic the wiring diagram for the connections between the L293D and the screw terminals is not correct.
Currently the schematic shows pin 11 of the L293D going to screw terminal position 3 and pin 14 going to position 2.
The actual connection is; pin 11 of the L293D goes to screw terminal position 2 and pin 14 goes to screw terminal position 3.
The PPDBs I have are all labeled correctly.
The current title of the pdf document should be "Propeller PDB schematic..." and not "Propeller PBD schematic..." . Picky, picky, picky.
Sandy
Sandy
