spin2cpp Byte and ~ Error
When converting the read_pulse_widths from the Eddie project I get the following error:
It looks like the problem code is
And the spin source:
read_pulse_widths.cpp:40:11: warning: promoted ~unsigned is always non-zero [-Wsign-compare]
uint8_t Cog;
int32_t read_pulse_widths::Stop(void)
if (~Cog) {
cogstop(Cog);
return 0;
VAR
byte cog
PUB Stop 'Stop the currently running cog, if any
if !cog
cogstop(cog)
It appears that there's an error in the original Spin code. The normal practice is to set Cog to the return value of cognew plus 1, and to test Cog for a non-zero value when doing a cogstop. The logic in the current Spin code is incorrect.
Oops. You're right: the spin code does have an error. I'm making a list of the bugs in Eddie so I'll be sure to add that one. Thanks for catching it.
