propeller c hello message not working
I am trying to get the hello message to work using c for the propeller but it is not coming up in the terminal when i run it.. I am doing everything the tutorial says to but its not working.
the tutorial is here
http://learn.parallax.com/propeller-c-start-simple/simple-hello-message
and i have my propeller BOE plugged in but the terminal is not coming up when i hit run with terminal :[
Edit:: Are you using the latest libraries and SimpleIDE software? Also, make sure you are opening the "project" and not just the file. I made that mistake in the beginning.
