Recommendations — Parallax Forums
Recommendations
ercoerco Posts: 20,263
edited 2013-07-18 08:34 in General Discussion
Edited for content.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2013-07-15 20:04
    I see where this is going!!!!
    edited 2013-07-15 20:12
    Erco,
    I'm afraid that information is proprietary and would give my competitors an unfair advantage if I revealed my sources and methods. Sorry. You'll just have to do the months of footwork that I went through to determine the exact specs you need and to find a reliable supplier.
    'Best of luck,
    edited 2013-07-15 20:17
    Edited for content.
    edited 2013-07-15 20:21
    Play nice now.
    edited 2013-07-15 20:23
    edited 2013-07-15 20:26
    Me Too! Edited for content!
  • tonyp12tonyp12 Posts: 1,951
    edited 2013-07-15 20:58
    Is this some type of sarcasm?, the details you ask are a little weird.
    If it's 10K and the tolerance is 5%, I'm OK with that as 9k to 11k will work just fine to.
    I could not see why an exact 10k resistor in a circuit could ever be needed.
    But for example
    10ohm, they come in 1% tolerance and if 10ohm is ok then 9.9 to 10.1 should probably be fine to.
    I never measure them unless I'm not sure what bag they come out of. on 0805 I look on the top to see the value xxy =value+0's
    edited 2013-07-15 21:16
    Thanks and yes, tonyp.
    Just letting off some steam. Sorry for any confusion. Editing now.
    edited 2013-07-15 21:17
  • Too_Many_ToolsToo_Many_Tools Posts: 765
    LOL...Hell has no fury like a ..... scorned.:smile:
    FWIW...your response (and thanks for responding) is a good one if the question had been a serious one.
    I would add that if any one has any older carbon resistors, you really should give them to someone you really do not like. (They drift like crazy over time due to moisture intrusion.)
    tonyp12 wrote: »
    But for example
  • Beau SchwabeBeau Schwabe Posts: 6,575
    edited 2013-07-15 21:25
    If only you could buy a car with the same specs ... 1%, 5%, 10%, heck I might even be up for 20% tolerance
  • xanaduxanadu Posts: 3,347
    edited 2013-07-15 21:27
    FYI - This post has 52 views and only 12 responses.
    edited 2013-07-15 21:30
    Make that 53 and 13!
    edited 2013-07-15 21:34
    Gotta be a buffering issue, dang dial up!
    edited 2013-07-15 21:47
    I always measure them, easier as squinting at those color stripes. Just to be sure.
    Because the first set I got from Parallax in the PE-Kit - they tend to move from bin to bin by themselves.:smile:
    I wondered about the tolerances, but by now all seem 'near enough' to me.
    Immediate resupply when needed was possible to RS but quite expensive (5 for $1.50?) but - just 10 miles away...
    It is a small town indy RS. One guy selling phones. So is not stacking all RS stuff. Yet the need stuff was always there!
    Even some switches, needed single LED, Banana plugs, things like that.
    I like those lure-boxes for fishing. Got one BIG one from Walmart.
    Has 4 sliding boxes (same as PE-Kit) and a couple of bigger bins to store small soldering iron, usb-scope, el al.
    Sort of traveling parts box. Will get another one.
    Good for storing PIRs, PINGs, PropPlugs, header, and other not so small items, but as mentioned above those adjustable bins
    are no good for small parts, they tend to move under the adjustable sliders and 'resort' themselves.
    For my next resupply I look for some stuff at jameico? two ready sorted and labeled assortments of resistors and capacitors in stackable boxes
    for about $100 I will have a lifetime supply I guess.
    I still stay away from smd parts, I barely can solder thru hole - my hands are shaking to much.
    That covers the OP questions I guess...
    Enjoy!
    edited 2013-07-15 22:11
    Edited for content.
    This appears to me to be a case of unnecessary editing.
    Thin ice, erco. Thin ice, dude.
  • WhitWhit Posts: 4,191
    edited 2013-07-16 05:58
    @ElectricAye - That is just wrong - funny, but wrong. :lol:
    edited 2013-07-16 06:06
    FYI, I edited it myself voluntarily. Neither a moderator edit nor request.
    edited 2013-07-16 06:20
    Self-editing is a good thing when done in moderation!
    At least you didn't <bleep> yourself!
    @ElectricEye: Whit is right!! I always wondered about Sesame Street and its messages!
    @erco - and your priest is proud of you!
    edited 2013-07-16 07:17
    Whit wrote: »
    So what's worse, Whit: censorship or sinnership? :)
    edited 2013-07-16 07:44
    Sinnership - censers are used in church all the time...
    http://en.wikipedia.org/wiki/Censer
    329 x 504 - 34K
    edited 2013-07-16 09:02
    Self-editing is a good thing when done in moderation! At least you didn't <bleep> yourself!
    Bleeping Beeping Beeps
    I just have to insert something here ... The other day we had some weather moving through, and the warnings kept "beeping" on the TV. To my surprise my oldest daughter says ..."Daddy, they must be saying a lot of bad words" ... innocence is bliss :-)
    edited 2013-07-16 09:40
    Guess I missed some good stuff ?
    edited 2013-07-16 10:23
    Cripes! Now my post is missing its context and just seems ... well ... mean.
    edited 2013-07-16 10:29
    Not edited for content...
    ...was just feeling left out... :)
    edited 2013-07-16 12:01
    Late to the game, Jeff!!!
    edited 2013-07-17 11:25
                         This post intentionally left blank.
    edited 2013-07-17 11:27
    Yeah, I'm late to the game as well. I've no idea what is going on.
    edited 2013-07-17 12:04
    I don't think you need to know what's going on as long as you contribute to the thread. (I'm several thousand posts into that theory!)
