Propeller + ttl camera — Parallax Forums
ohVaNiLLaGoRiLLaohVaNiLLaGoRiLLa Posts: 33
edited 2013-07-16 09:44 in Propeller 1
I have recently gotten a TTL Serial JPEG Camera with NTSC Video, http://www.adafruit.com/products/397, from adafruit and i was wondering if anyone could help me out with getting the propeller to save jpg pictures from the camera.
I took a look at the arduino library they have for the camera but im not completely sure on what they are doing since i have no experience with the arduino. any help or a point in the right direction would be appreciated
    edited 2013-07-15 15:36
    What do you want to save the pictures to? A SD card?
    The Prop isn't going to be able to interpret the data in the jpg file but it could probably read from the camera and write the data to a SD card.
    edited 2013-07-15 21:30
    As Duane states the prop can read the data from the camera and save it to an sd card. The "protocol cheat sheet" lists all the functions so it should be able to control the camera as well.
  • ohVaNiLLaGoRiLLaohVaNiLLaGoRiLLa Posts: 33
    edited 2013-07-16 07:58
    Yes I just want to save the jpg to a micro sd card. is there a good object for saving stuff to a micro sd card?
    This seem to be a common object for SD card use. I've used it myself many times.
