I would like to write and test spin code when I am without a propeller board.
Greetings,
I would like to write and test code in spin when I am without a propeller board. I was wondering if there is a spin or propeller simulator I can run on my windows computer?
I had the same thought but don't have time to write one, how about you?
Compile program to .binary file.
spinsim -b file.binary
sh-3.1$ ./spinsim.exe SpinSim Version 0.54 usage: spinsim [options] file The options are as follows: -l List executed instructions -l <filename> List executed instructions to <filename> -p Use PASM Spin interpreter -# Execute # instructions -P Profile Spin opcode usage -m# Set the hub memory size to # K-bytes -t Enable the Prop 2 mode -b# Enable the serial port and set the baudrate to # (default 115200) -gdb Operate as a GDB target over stdin/stdout -L <filename> Log GDB remote comm to <filename> -r <filename> Replay GDB session from <filename> -e Use eeprom.dat
