No output from PIR sensor
I purchased the PIR sensor Rev B and it works fine, based on the red light lighting up to detect motion and while it is calibrating. However, there is no signal from the output pin. I have tested several times, and there is zero volts and zero amperes coming from the output pin. I tested for shorts and everything. I have also contacted support to no avail. Does anyone have any suggestions?
