Source of Stepper Motors — Parallax Forums
JonnyMacJonnyMac Posts: 9,795
edited 2013-07-12 13:57 in General Discussion
I'm helping a friend with a prop (as in theatrical prop, not the Propeller -- though we will use the Propeller to run it!) that requires two stepper motors. I'm looking for a reliable source of steppers as he may need to build several if all works out. Thanks!
    edited 2013-07-11 15:26
    Jon,
    I've never bought stepper motors except as surplus, due to the price differential vs. new. Assuming the latter is what you're looking for, however, try Stock Drive Products/Sterling Instruments:
  • WhitWhit Posts: 4,191
    edited 2013-07-11 15:28
    What kind of other properties do you need in the motor?
  • W9GFOW9GFO Posts: 4,010
    edited 2013-07-11 16:34
    What size of stepper do you need? I've got a couple dozen NEMA 34 from EAD (Eastern Air Devices).
    edited 2013-07-11 23:22
    If you are looking for options and want to buy from a place that will be around for a while, try Automation Direct. Been very happy with them for steppers and PLCs for various pieces of equipment since ~2002.
    edited 2013-07-11 23:28
    Much depends on the size stepper motors you need.. big powerful ones have an array of industrial suppliers.
    But for the small tiny ones with good controller support... try Pololu. They have an excellent selection with related hardware and all are 200 steps.
    edited 2013-07-12 03:32
    These are #23, fairly stable source: http://www.hobbycnc.com/products/stepper-motors/
    edited 2013-07-12 09:46
    Phil, thanks for the pointer, I'll take a look at them. Something that drives me crazy about buying used or surplus steppers is that the seller will often list the form factor (e.g. NEMA 23), but not the torque. Those guys look like they list both.
  • JonnyMacJonnyMac Posts: 9,795
    edited 2013-07-12 10:15
    Thanks for the feedback. Right now we don't know what we don't know and will probably make a prototype with motors I can pick up over at All Electronics. Long term, though, we'd rather go with a stable source.
    The project is a Ouija board gag. A Propeller circuit will allow an operator to select an answer and an XY arrangement underneath will move the puck to spell it out.The puck will be magnetically coupled with the carriage.
  • dgatelydgately Posts: 1,646
    I've heard that these were excellent for 3D Printers, so should be fairly stable and dependable: http://shop.evilmadscientist.com/productsmenu/partsmenu/187-stepper
    dgately
