IR Receiver Question
NWCCTV
If I were to reduce the value of the resistor on this IR Receiver would it be possible to run it at 3.3V instead of 5V?
NWCCTV
Or this 2.7V IR receiver which is also continuous signal acceptable. Fixed gain, sensitive.
Parallax should consider stocking these. Very useful IMO. Allows IR detection & tracking.
http://www.mouser.com/ProductDetail/Vishay-Semiconductors/TSOP4038/?qs=oO6ELfDJL3fM5etQKIfesw==
http://www.robotroom.com/PNA4602M-Replacement-1.html
With the above circuit, I was able to generate 5V @10 mA. I would recommend adding a 5.1V zener in parallel with the output, though, just to eliminate the possibility of over-voltage.
Well, what have you got?
And what's the source for the "3V", a couple of "C" batteries?
I'd actually try one at the lower voltage, just to make sure. Won't hurt it. If it needs the >4.7v, you will know instantly. Assuming the use of something like a Prop BOE or Prop Activity Board, you have a source of 5V if needed. I'd be sure to get that 1K resistor in series.
-- Gordon
EDIT: I guess they are not Sony, they are these ones from EGM. Anyone know how to connect and code these things?
