Diptrace and thru hole boards
Ray0665
I Fabricated my first ever PCB recently and the board worked just fine but I see I have a few improvements to make before I try it again.
For this first boardI used diptrace and all the defaults.
There are basically three things I need to change to make my thru hole boards easier to assemble by hand The drill holes were on the small side as were the pads, the traces were a little too thin and the space around the pads was too small.
So my questions is which of the setup options in diptrace should be used for thru hole technology that could be considered standard
