SimpleIDE vs Propeller tool — Parallax Forums
FrannyFranny Posts: 127
edited 2013-07-12 12:03 in Propeller 1
Does anybody know why when I run spin code from the propeller tool into a proto board it works just fine with servos and LEDs, etc. but when I run the Simple IDE examples they don't work?
  • jazzedjazzed Posts: 11,803
    edited 2013-07-09 05:07
    Franny wrote: »
    Since today's SimpleIDE is project based, my guess is you didn't Set Project for the open tab in SimpleIDE with F4 or by Menu->Project->Set Project.
    Propeller tool will compile and load any tab that is displayed.
    edited 2013-07-09 07:01
    jazzed wrote: »
    Would there be a way for it to detect the project was not set, and inform the user?
    edited 2013-07-09 07:28
    It complains if a project is not set. What it doesn't do is complain if a project is set and the tab doesn't match the project.
    There may be a few simple things I can do for Spin "projects" to keep people out of the user guide ....
  • FrannyFranny Posts: 127
    edited 2013-07-09 08:57
    the F4 worked Thanks!
    edited 2013-07-09 09:07
    jazzed wrote: »
    I don't recall finding a user guide when I was in there a couple months back. Is the user guide accessible, perhaps via the help option?
    edited 2013-07-09 09:17
    There is in more recent versions. I think it's best not to upgrade until the next announcement though unless there is a very specific reason.
    edited 2013-07-09 09:28
    Why does a project have to be set? Is it because of library locations?
    edited 2013-07-09 09:33
    Franny wrote: »
    Because that's the way it was originally designed. Then someone said, oh, you should add SPIN and 1000 other features ....
    I have an experimental version that will let us use either methodology but that will take some testing.
    edited 2013-07-09 10:43
    Looking through all of the threads happening now I'm wondering is SimpleIDE going to end up using BSTC or something else to compile Spin/Pasm? Also was wondering if there is going to be a new Propeller2 tool (like the current Prop1 tool) in addition to SimpleIDE?
    edited 2013-07-09 11:12
    ratronic wrote: »
    SimpleIDE has always used BSTC for compiling. We will move entirely to Roy's OpenSpin in the near future.
    Ken asked me to make a Propeller-Tool-ish version of SimpleIDE just for SPIN ... to be named.
    edited 2013-07-09 11:21
    I rather liked the first Propeller tool. Ken has some really sharp people working on this. I can't wait to see what you guys put together.
  • JonnyMacJonnyMac Posts: 9,795
    edited 2013-07-09 11:35
    Well, I'm certainly guilty of that (I even called Ken to suggest adopting SimpleIDE for Spin) because you've done such a FANTASTIC job with it, Steve. As new as it is, SimpleIDE feels far more "finished" and refined than the Propeller Tool. If you add color background (ala P/T), you'll be my best friend forever! :)
    edited 2013-07-09 12:01
    Ya, I've heard the call. Education stuff is top priority though.
    The Propeller-Tool-ish SimpleIDE should be like the old Propeller-Tool except:
    • It will be multi-platform.
    • It will be multi-lingual.
    • Will use UTF8 translated from UTF16.
    • Package size will be a little different.
    • Will try to keep the existing bug list too just for Phil.
    edited 2013-07-09 13:40
    Thanks! : ]
    Stand on the bow of a boat and stretch out your arms -- you are the king of the world! :)
