TV Problem
Hello everyone!!!
I wonder if anyone can help me with the TV object for the propeller chip.
Working on a little home project where I use XBee to send some serial information to a propeller and show this on a tv.
But it seems after a while the whole application is getting stuck some how.
It seems to happen when I change the color on the cursor.
Made a small test program to send a bunch of random text and changing color and after a little wile the tv object is getting stuck.
I do not know why
Here is the code for the both applications
This is the code for the Tv unit
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
XB_Rx = 0 ' XBee DOUT
XB_Tx = 1 ' XBee DIN
XB_Baud = 9600 ' XBee Baud Rate
OBJ
text : "tv_text"
xb : "XBee_Object"
var
long DataIn
PUB start | i
XB.start(XB_Rx, XB_Tx, 0, XB_Baud)
'delay(1000)
'start term
text.start(12)
delay(1000)
main
pub main
repeat
DataIn := XB.RX
if DataIn == "@"
command
if DataIn <> "@"
text.out(DataIn)
pub command
delay(5)
repeat
DataIn := XB.RX
If DataIn == "1" 'clear screen
text.out(0)
Done_cmd
main
if DataIn == "2" 'cursor home
text.out(1)
xb.rxflush
Done_cmd
main
if DataIn == "3"
text.out($C) 'color 0
text.out(0)
xb.rxflush
Done_cmd
main '
if DataIn == "4"
text.out($C) 'color 1
text.out(1)
xb.rxflush
Done_cmd
main
if DataIn == "5"
text.out($C) 'color 2
text.out(2)
xb.rxflush
Done_cmd
main
if DataIn == "6"
text.out($C) 'color 4
text.out(3)
xb.rxflush
Done_cmd
main
if DataIn == "7"
text.out($C) 'color 5
text.out(4)
xb.rxflush
Done_cmd
main
if DataIn == "8"
text.out($C) 'color 6
text.out(5)
xb.rxflush
Done_cmd
main
if DataIn == "9"
text.out($C) 'color 7
text.out(6)
xb.rxflush
Done_cmd
main
if DataIn == "0"
text.out($C) 'color 8
text.out(7)
xb.rxflush
Done_cmd
main
if DataIn == "A"
reboot
main
main
Pub Delay(mS)
'' Delay routing
'' XB.Delay(1000) ' pause 1 second
waitcnt(clkfreq/1000 * mS + cnt)
pub Done_cmd
xb.tx("D")
delay(100)
The sender application is attached
As long as I do not change color on the cursor I can run this for days, but as soon as I start to changing colors and writing text with different colors the system is getting stuck somehow.
Wonder if anyone has any idea why.
Best regards
Mr.Walters
I do not know why
CON
OBJ
text : "tv_text"
xb : "XBee_Object"
var
long DataIn
PUB start | i
'delay(1000)
'start term
text.start(12)
delay(1000)
main
pub main
repeat
DataIn := XB.RX
if DataIn == "@"
command
if DataIn <> "@"
text.out(DataIn)
pub command
delay(5)
repeat
DataIn := XB.RX
text.out(0)
Done_cmd
main
text.out(1)
xb.rxflush
Done_cmd
main
if DataIn == "3"
text.out(0)
xb.rxflush
Done_cmd
main '
if DataIn == "4"
text.out(1)
xb.rxflush
Done_cmd
main
if DataIn == "5"
text.out(2)
xb.rxflush
Done_cmd
main
if DataIn == "6"
text.out(3)
xb.rxflush
Done_cmd
main
if DataIn == "7"
text.out(4)
xb.rxflush
Done_cmd
main
if DataIn == "8"
text.out(5)
xb.rxflush
Done_cmd
main
if DataIn == "9"
text.out(6)
xb.rxflush
Done_cmd
main
if DataIn == "0"
text.out(7)
xb.rxflush
Done_cmd
main
if DataIn == "A"
reboot
main
main
Pub Delay(mS)
'' Delay routing
pub Done_cmd
xb.tx("D")
delay(100)
Best regards
Mr.Walters
Also, please wrap code in [noparse] [/noparse] tags, it's easier to read.
Made the changes you suggested and now it is working fine.The system has been runing for 24 houes with out getting stuck
Best Regards
Mr.Walters
