Breadboard Computer — Parallax Forums
  • ercoerco Posts: 20,259
    edited 2013-07-06 20:59
    Cool, but that's quite a daunting rat's nest of wires. BUT this related article about a mechanical CPU clock was cool. This guy should sell a kit.
    http://www.instructables.com/id/Mechanical-CPU-Clock/
  • ajwardajward Posts: 1,130
    edited 2013-07-06 23:25
    that looks like all the cabling behind my desk!
    edited 2013-07-07 06:56
    There's no way I could wire that and not make an error I could never find.
    edited 2013-07-07 07:42
    A couple of years ago, there were photos of Z80 CPU, implemented using logic ICs, on breadboard also.
    edited 2013-07-07 07:43
    Good grief. Back in the early 80s I used to wirewrap prototype 8 bit computer boards. I used to worry like hell that those connections would not get disturbed. This is something else.
    edited 2013-07-07 07:52
    I have a couple cats that were eying those breadboards with great interest. They like to "help" when I breadboard something.
    One of my favorite field repair kits for the Sperry mainframes I worked on was an envelope that contained a length of wirewrap wire (maybe 24-36 inches) and an instruction sheet with two pin numbers for spots on the wire-wrapped backplane where you needed to replace a shorter wire. The new wire introduced a delay in a cache invalidate signal or some such timing thing. It was always a little daunting to open up the back of a refrigerator sized cabinet and find those two pins on a refrigerator sized backplane and take out the old wire and put in the new wire. A simple but effective fix unless you miscounted.
    edited 2013-07-07 08:07
    Reminds me to start ordering a bunch of those breadboards, a handful of those PSUs, oh, and...
    did someone spot those wires on eBay?
    edited 2013-07-07 12:07
    There were around photos of Intel Pentium PRO processor prototype - the last Intel CPU that was prototyped using discrete transistors! It occupied two large rooms and run at 20khz or something like that. All later Intel CPUs were modeled in software.
    edited 2013-07-07 12:58
    Reminds me of the first computer I worked on (Collins 8400). It consisted of 2 rows of 5 or 6 cabinets, each cabinet being about a foot deep, 3 feet wide, and 6 feet high. The density of wiring in the back of those cabinets was even higher than this protoboard.
    Also read some articles in even earlier issues of the IEEE Transactions about the density of the "wiring nap" and the length of the signal wires limiting the size and speed of computers. Of course those were written before IC's came to the rescue.
    edited 2013-07-07 15:24
    The Cray-1 got its 'C' shape because of the necessity to keep some wire interconnects short.
    edited 2013-07-07 22:17
    Heater. wrote: »
    I wouldn't worry more about old wirewrap boards than solderless breadboards. I have both, from yesteryear, and they continue to work. Corrosion was always a concern, which turns out not to be a problem. Today I worry about new things, like stressing the spring constant in the connection.
