Cogs trampling over one another?
Hugh
What are the possible ways that one cog could trample over others and stop them working? If I start a cog with COGNEW, '6' is returned (so I haven't run out of Cogs) but other processes in other Cogs appear to be halted/not start.
Both referencing the same pin?
Both referring to the same variables?
Anything else?
Hugh
Anything else?
Hugh
I have pared the declared stacks to the bone. Stack/Free is 4584 longs according to the F8 ObjectInfo (Program 2907 longs, Variables 697 longs)
Having started all of the cogs I need to, '6' is returned so I haven;'t run out of cogs.
I have deleted 50 longs worth of code.
Even having freed up more space, uncommenting the line marked 'This line' stops everything. In fact, even a waitcnt in that line stops things.
I have added the following PUB and called this via COGNEW before any other cogs are started:
The number returned by the last cog to start is still 6?
Is there a 'head-scratching' icon?
I've learned to make it a general policy to only set pins from a single cog.
Are you using any video display objects? I know there's at least one video object that doesn't declare all the memory it uses.
As usual, I agree with kuroneko. It would really help if you posted your code.
Having called COGNEW several times I forgot to take into account that 'FullDuplexSerial' (called twice) starts a new cog - there won't be one available.
Does anyone know if 'Simple_serial' starts a new cog (it doesn't say it does)?
Off to kick myself - hard!
Hugh
No, it doesn't and everything works fine now.
Schoolboy error...
