"Impossible 3D Print": Bearings
Well done. Not sure how smooth or durable, but quite impressive.
Jump to 3:55 to see the bearing in action:http://www.youtube.com/watch?feature=player_detailpage&v=Ak03wmi-3FE#t=235s
The video shows them being broken loose with an awl before the bearings will rotate.
But why would I want plastic ball bearings rather than hardened steel?
Next you can try to build 31 balls inside of balls, or a giant babuska doll. http://en.wikipedia.org/wiki/Matryoshka_doll
3D printing seems most useful for making complex geometries that my CNC machine can't do...at that point, my brain will melt...unless there is some magic software out there... really cheap.
http://www.planet-cnc.com/index.php?page=software
thanks. Nope I hadn't seen it. I use Mach3, which is well worth the money.
What I find most interesting is that it the software that you linked to http://www.planet-cnc.com/index.php?page=softwarecan reverse g-code into various formats. I find that very intriguing.
I can't try it right now, because I'm on a Mac. But it is definitely worth a look see.
I tried various routes, before deciding to just role my own g-code. The one I remember best is trying to use sketchuphttp://www.sketchup.com/ to design a small part and then import the result into various software that is supposed to generate g-code. Sketchup is a real treat. I wouldn't recommend it:) But it is free and I did manage to find a way to use it. Example... a hole in a plate. This is not easy to accomplish without studying Sketcup more than I would like, but I did manage to generate a model for export to software that was supposed to turn it into g-code. Software invariably interpreted the hole as a pocket, even though it was a through and through hole. So, rather than cutting
a circular path at incremental depths, which takes very little time and generates very little detritus, the hole was removed bit by bit by pocket style logic, which takes a lot of time and generates a mound of debris. Possibly this kind of thing wouldn't be as much of a problem with a 3D printer, which uses additive logic.
I am interested in 3d printing... particularly the lithography type approach, but the machine style is getting so cheap, I don't think I can hold out much longer.
Rich
