Have you listened to your Memsic2125 ... Lately? — Parallax Forums
Beau SchwabeBeau Schwabe Posts: 6,576
edited 2013-07-01 22:26 in General Discussion
Ok, so I was fiddling with a metal detector circuit to take up to Michigan later this month to see if I could comb the beach for some left over 4th of July pocket change people might have lost. ... Anyway, I came across a cool little add-on circuit that makes it real easy to hetero-dyne two signals as long as they are about 400mV apart from one another. Looking around to see what I have in the way of sensors that I could apply this circuit to I spot a Memsic 2125 .... Hmmm .... Only the output frequency is only 100Hz. That's OK, In the back of my mind, I remember Jeff Martin doing a scope experiment on the Memsic and discovered that the Start edges between X and Y happened at exactly the same time. This means we can "hetero-dyne" on the signal edge or ERROR between the X and Y.... assuming that at level the X and Y are identical. <-- and they are, we lucked out.
Schematic:
Here is a video of the result:
http://www.youtube.com/watch?v=8Q2PgoHpcIo
1024 x 431 - 33K
