Somewhere around here I have an 1802 in a ceramic package. I should see if I can dig it up and exchange it with the plastic one in my framed COSMAC Super ELF.
will happily sell it to you for 1/10 of quoted price
How embarrassing to think that a modern micro SD card could kick that ancient module's sorry behind in capacity, power, size, weight, MTBF, maintainability, etc.
More like a modern 8-pin serial EEPROM. That core module is only 4096 words by 18 bits, or just a little over 8 kilobytes at 400 KHz.
@localroger: You and I both got the EG grab bag of ICs recently, maybe a hundred ICs in there. Hang onto those and eventually the collection may be worth $10,000!
Actually, given the number of SD cards that have become unusable on me over the past year or so I would say their MTBF is some millions of times worse than ferrite core store.
Depending on the size & nature of the nuclear blast, that particular warranty may be difficult to enforce and collect on. Somewhat like a parachute warranty.
I've seen internals of russian anti-aircraft missile (old model, trough). It was amasing - it had kind of analog "computer", without any transistors of vacuum tubes, all logic was done by magnetic amplifiers and switches!
Well.. if you took a bad photo it would turn out purple.
But most chips of that era would have lot number on the top , and date code along with the country of origin on the bottom. This one is missing the date code.
A faulty liferaft is even harder to collect on. The parachute is most likely to land on land resulting in someone looking at the failure
-Tor
http://www.ebay.com/itm/USSR-Soviet-Russian-Military-Ferrite-Core-Memory-Stack-Cube-MANUAL-QUITE-RARE-/150928595047?pt=LH_DefaultDomain_0&hash=item23240b9867
I used to put these up at 70-100 dollars each when I need some PayPal money. Would sell in minutes. Most buyers were Japanese.
The 4004's seemed to come through rather well. Guess it's that good old lead.
Need to take a better picture later.
... and the old computers too.
