spin2cpp multiple {++ volatile} dat sections error — Parallax Forums
SRLMSRLM Posts: 5,045
edited 2013-06-29 11:54 in Propeller 1
When I convert the following spin file:
Dat {++ volatile}
Power
RightPower    word      0
LeftPower     word      0
Dat {++ volatile}
              org
Entry
              mov       dira, OutputMask        ' set outputs
              mov       ctra, CTRA_Setting
              mov       ctrb, CTRB_Setting
              mov       frqa, #1                ' frq is added to phs every clock cycle
              mov       frqb, #1                ' so it takes -phs clockcycles to generate a falling edge
I get the following in the .h file:
static uint8_t  volatile  volatile dat[];
Which produces
In file included from eddie_motor_driver.cpp:8:0:
eddie_motor_driver.h:25:3: error: duplicate 'volatile'
eddie_motor_driver.cpp:19:1: error: duplicate 'volatile'
I'm using spin2cpp version 1.04 from the propgcc version alpha_v1_9_0_2042 on Ubuntu 13.04.
  • ersmithersmith Posts: 6,277
    The DAT sections are all merged, so if any one has {++volatile} on it they will all be volatile. So you only need that declaration once.
    That said, spin2cpp should handle the multiple declarations, so thanks for the bug report.
    Eric
