How to use {++ } feature in spin2cpp? — Parallax Forums
SRLMSRLM Posts: 5,045
edited 2013-06-29 11:52 in Propeller 1
How do I use the spin2cpp feature to pass through code to the C++ output? I tried
// my comment
and
// my comment
and
// and here are the C versions of the methods
int32_t test95::Square(int32_t x)
  return x*x;
And I get
../spinsource/quadrature_encoder.spin:48: syntax error
The line reference is the line immediately following the {++ } annotated block.
What am I missing?
  • ersmithersmith Posts: 6,281
    I can't tell from what you've posted; it looks like it should work. It may be that your particular form of {++ has to go after a PUB or PRI declaration (I think I've only really tried testing C++ functions after Spin functions). See for example Test/test95.spin in the spin2cpp source code:
    { indicate to spin2cpp that it should not output Spin methods }
    {++!nospin}
    { the Spin version of the methods }
    PUB Square(x)
      return x*x
      return x*x;
