VGA Driver Advice
Hi all
I have a little project that requires a 3 digit number (0 - 255 received via DMX) to be displayed on a VGA monitor. Ideally the characters will be take up most of the display. A screen resolution of 800 x 600 resolution is acceptable.
Can anyone suggest a suitable driver from the OBEX. This is my first (ad)venture into the world of Prop VGA and just need a little nudge in the right direction.
And then I will probably let loose a barrage of questions when all else fails.
I will be building the project using a Proto Board.
Thanks in advance
Lindsay G
Thanks in advance
Lindsay G
It allows you to overlay text and other ansii chars on your vga display.
Item code
28327
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/28327/List/0/SortField/4/ProductID/602/Default.aspx
Also, I am interested in doing some work with DMX on the propeller... can I ask for some details as to how you are generating/receiving the DMX signals?
I would like to be able to decode DMX signals from lighting equipment. Later I would like to make my own DMX controller.
Do you have a part number or schematic of what you are running off the propeller for your DMX work?
Thanks for the comment on the backpack. I am not overlaying though. Rather I want to simulate 3-digit LCD type display full screen on a VGA monitor.
Re DMX:
I usually use jm_dmxin and jm_dmxout. Both of which can be found in the OBEX. Jon "JonnyMac" McPhalen (aka Jon Williams) is the creator of these objects and is one of the forum experts on DMX. Another is hippy.
I have also used DMX-512A Receive Driver.
All very easy to use.
I usually use a MAX488 RS485 IC as this allows independent rx and tx unlike some other IC's of the same type There are cheaper IC's that allow you to select either tx or rx at anytime e.g. the SN75176.
When receiving the serial data from any 5V RS485 receiver it is important to either use a 5V to 3V level converter or a potential divider to ensure you don't damage your Prop.
It is important to provide adequate isolation of your home-brewed DMX controlled equipment if using in a professional/commercial environment. There are a variety of circuits available (you can use Google (Image) search) to locate one like this. The optoisolator (6N137)and the DC-DC converter provide the required isolation.
I am currently (longer term project) attempting to redesign an AVR project that emulates a DMX Pro interface using the Prop. Slow progress as it is a bit of a side project.
Cheers
Lindsay G
Hi Mike
Thanks for the reply. I will look into it and see how I go. I have a couple of weeks before it is needed so plenty of time for me to explore this.
Cheers
Lindsay G
@Mike:thankfully the rest of the program is minimal in that it only needs to read one DMX channel and pass that on to the display object(s).
Probably a lot of questions later.
Thanks for your assistance.
