Just Getting Started
w4op
I just downloaded the Basic Stamp software. In setting it up, one page asks me to ID the Stamp board I have. Mine is not listed- it is the 2712 Serial board.
Is one of the two serial boards listed equivalent?
Dale
Dale
The Stamp Editor tries each of the serial ports available under Windows to see if it responds like a Basic Stamp with the model and firmware version which the Editor displays. That's what's meant by ID. What Stamp board are you using? What Stamp model is installed on it? (BS2, BS2sx, BS2p, BS2pe, BS2px? other?)
https://www.parallax.com/Store/Microcontrollers/BASICStampDevelopmentBoards/tabid/137/CategoryID/12/List/0/SortField/0/Level/a/ProductID/121/Default.aspx
The Basic Stamp I have is the BS-2. I have the program file and just want to load it into the Stamp.
Dale
The SuperCarrier Board does need power for programming and a 9V battery will work for that, but for other uses, you really need an AC-powered supply. It doesn't have to be 9V. Anything above about 6V will do. Remember that the Stamp's built-in regulator can't really supply much to run other stuff. There's a total of 50mA available, less if you use a supply voltage much above 6V (because of the heat dissipation needed).
