QuickStart Rev A vs Rev B? — Parallax Forums
David BetzDavid Betz Posts: 14,530
edited 2013-06-29 08:35 in Propeller 1
Does anyone know the difference between QuickStart Rev A and Rev B? I have four QuickStart boards and three are Rev A and one is Rev B. It looks like the circuitry around the FTDI chip is different as is the chip itself. Are there any functional differences between these two revisions or should they be interchangable?
Edit: One interesting difference is that the Rev A is labeled "P8X32A QuickStart" and the Rev B is labeled "Propeller QuickStart".
  • BeanBean Posts: 8,129
    edited 2013-06-28 11:41
    David,
    I know the original quickstarts only had a 32K eeprom. Now they have a 64K eeprom.
    Bean
    edited 2013-06-28 14:08
    Bean wrote: »
    David,
    Bean
    I don't think they changed the revision from A to B when they added the 64K EEPROM because I have two QuickStart boards that are labeled Rev A that have 64K EEPROMs and the part number on the EEPROM chip is the same as on my new Rev B board.
  • TorTor Posts: 2,010
    edited 2013-06-29 07:51
    My Rev. A versions have 64K EEPROM. I would guess that there was an original version with 32K, and then the first revision arrived.. which would be Rev. A, and maybe that's when the 64K arrived. I have one Rev. B QS and, as with David's my Rev. B says 'Propeller QuickStart' instead of 'P8X32A QuickStart'. The changes do seem to be around the FTDI. And the Rev. B on mine has some golden transparent plastic on the top of the USB socket, the Rev. A doesn't.
    -Tor
    Wasn't the Rev B about the magic resistor? I think it was the 100k pull up from Tx to 3.3v to address the intermittent "prop not found" error on some quickstarts on some PC's? I think this issue was also addressed in the update from prop tool 1.2 to 1.3.2, but might be confusing myself again.
