Help with my first code using multi cogs. I am a super begginer
Hi buddies.
I am from Mexico and never I programmed propeller´s chip. It is not common propeller in mexico but I have worked with Pic18f
I have read about the spin code and I have the following code but it doesnt work
. I want to do the led blinking wit diferents cogs in diferents pins. I do not what I doing bad.
PS:: I using the Gear debugger and also the propeller tool.
PS2: sorry for my poor english , I am not good.
con_xinfreq=20_000_000
_clkmode= xtal1+pll4x
VAR
long cog1Stack[120]
long cog2Stack[120]
long cog3Stack[120]
long cog4Stack[120]
long cog5Stack[120]
long cog6Stack[120]
long cog7Stack[120]
PUB HUB
coginit(1,nucleo1,@cog1Stack)
coginit(2,nucleo2,@cog2Stack)
coginit(3,nucleo3,@cog3Stack)
coginit(4,nucleo4,@cog4Stack)
coginit(5,nucleo5,@cog5Stack)
coginit(6,nucleo6,@cog6Stack)
coginit(7,nucleo7,@cog7Stack)
PUB nucleo1
dira[14]~~
repeat
!outa[14]
waitcnt(3_000_000 + cnt)
PUB nucleo2
dira[15]~~
repeat
!outa[15]
PUB nucleo3
dira[16]~~
repeat
!outa[16]
PUB nucleo4
dira[17]~~
repeat
!outa[17]
PUB nucleo5
dira[18]~~
repeat
!outa[18]
PUB nucleo6
dira[19]~~
repeat
!outa[19]
PUB nucleo7
dira[20]~~
repeat
!outa[20]
Problem 1:
Your CON block clock setup needs a carriage return. Try this (if you are using a 20 MHz crystal):
CON
_clkmode = XTAL1+PLL4X
_xinfreq = 20_000_000
Problem 2:
Look at your repeat code. The !outa and waitcount lines should be indented underneath repeat, to be part of the loop:
The little blue lines make it easier to read blocks. You can turn them on and off with CTRL+i.
https://beta.www.parallax.com/downloads/spanish-translations-espanol
