Running the Prop Protoboard from a different 5v and 3.3v source?
I have designed a power supply circuit to use for a prop project and need to test it in my vehicle. I am currently using an LM317 to adjust to voltage going into the prop protoboard down to 9V to prevent the board from getting too hot and popping any components. Is there a way to bypass the onboard power circuit without having to remove the regulators? I would like to power the protoboard solely from my circuit which outputs 5V and 3.3V.
Applications Section - page 7
I'm pretty sure you can just hook-up 3.3V to Vdd and ground to ground and you are good to go. I say pretty sure because I've never done it and haven't really looked at the regulators for a while. I think the point of cavelamb's post was so that you could resolve the issue of reverse current through the 3.3V regulator. I do know for sure that you can just cut out the Prop chip and surrounding assigned (dual pin) arrangements and then feed 3.3V to the gutted ProtoBoard. This is fun... there are some threads about it... don't know where, but someone will chime in if you are interested. The end result is a credit card size Prop board, which you can power with 3.3V to Vdd.
IMHO, you need to order lots of 5 Protoboards... that way you can just do it!!!! And if it doesn't work, what the heck?
Rich
Careful though. putting anything much higher that +5V in to the barrel connector could be bad.
