Emic 2 Text-to-Speech questions
Im haveing a hard time changing the voice in the program. The manual says that "Nx 0-8" can be used to select the voice.
How do you put that in the progam? Anyone?
The "x" in "Nx" is the number of the voice you want to use.
Assume "Serial" is the serial object used to communicate with the Emic2. I think this code should change the voice to voice number 4.
I haven't used other voices myself, but I've used the "V" command to set the volume. Both the volume command and the voice command (and many of the others) work the same way.
Thanks any how Duane
