FT232RL USB To UART Interface
Hello my name is Victor
I am building my own proplug for to use with the Propeller P8X32A , I am using the FT232RL, but I can not get communication with the Propeller, I have a error : No chip Propeller found in COMxx
I want know if somebody can help me please , if somebady can send me the Diagram for to use the FT232RL o tell me wat I can do.
Thank.
Thank.
Oh, where are my manners......Welcome to the Propeller forum Victor. After a while you will get to discern our personalities and figure out that we are very friendly and being helpful even if sometimes that may sound a little chiding.
The Demo Board schematic is available under the help menu in the Propeller Tool.
BTW, Welcome to the forum.
Please be aware that multiple posting across the Forum is against the rules:
http://forums.parallax.com/showthread.php/134682-Forum-Guidelines
Thanks and regards.
http://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT232R.pdf
In this case it may only be the package... on the other hand, a different package may require a different pin out arrangement.
The Q has 32 pins; the R has 28 pins.
You can locate a PDF for the right chip on the order page in the Parallax store.
Straight from page 1 of the datasheet form the link provided:
FT232RQ-xxxx 32 Pin QFN
FT232RL-xxxx 28 Pin SSOP
Thank you for your help.
