Trying to read voltage with MCP3002 but all pins read source voltage
After successfully getting my LM34 working with my ADC0831 thanks to help from the forum I have moved onto the 2 channel MCP3002. I attempted to get it working with a simple proof of concept by reading voltage off the first channel. I hooked everything up as I saw it on the datasheet with a reference and source voltage of 5volts as supplied by BS2 BOE.
After first loading the code and running it, I had a debug screen which showed me 5volts. Seeing as I was measuring 5volts, I assumed it was working fine. However, I quickly found out that it read EVERY value as 5volts. After unhooking my voltage sources from the channels and getting my meter I saw both channels and the Vref pin are all putting out ~5volts when disconnected. I believe it is caused by a problem with the initialization code and testing with a second MCP3002 gets me the same readings on my meter.
I was able to find examples for the MCP3008 and the MCP3208, but only really able to find examples for hooking the MCP3002 to a Raspberry Pi which was confusing at best for me. I found one bit of code which I used for initialization process that had no real documentation and could very well be bad.
Input?
LM37_MCP3002-FORUM.BS2
Input?
' {$STAMP BS2}
' Notes: This code was pieced together from bits found on google and Stamp Works experiment #27 found at
' URL: http://www.parallax.com/dl/docs/books/sw/exp/sw27.pdf
' The scavenged code from google was mostly for the initialization process(Which I assume is incorrect).
' I used the Stamp Works code to read and display the result as a voltage for a proof of concept. I realize
' I'm pulling less data that the ADC is capable of, but I believed it simplified things for testing.
' I/O Definitions
A2DdataO CON 6 ' A/D data OUTPUT line
A2DdataI CON 3 ' A/D data INPUT line for selecting channels.
A2Dclock CON 1 ' A/D clock
A2Dcs CON 2 ' A/D chip select (low true)
' Variables
result VAR Byte ' result of conversion
a2dchan VAR Nib ' A2D channel selector
mVolts VAR Word ' convert to millivolts
' Program Code
Main:
a2dchan = 0 ' Sets channels to 0 ?
GOSUB InitADC
GOSUB ReadData
GOSUB PrintData
PAUSE 1024
GOTO Main
' Subroutines
' Prepare the ADC for data acquisision
InitADC:
HIGH A2Dcs ' Pull CS high to ensure it's reset
PULSOUT 1,A2Dclock ' Use clock pulse to advance communication
' Start bit
LOW A2Dcs ' Pull CS (Chip Select) pin low to initiate communication
SHIFTOUT A2DdataI, A2Dclock, 0, [1\1] ' Send '1' to DIN and a CLK pulse for start bit
' SGL/DIFF bit
' 0: 1 chan differential mode
' 1: 2 chan singled ended mode
' ODD/SIGN bit
' 0: for chan 0
' 1: FOR chan 1
SHIFTOUT A2DdataI, A2Dclock, 0, [a2dchan\1]
' MSBF bit (Most Significant Bit Flag)
' 0: MSB data followed by LSB data
' 1: just output MSB data
' Although testing seems to indicate these bit settings are reversed
SHIFTOUT A2DdataI, A2Dclock, 0, [0\1]
'LOW DIN
'PULSOUT 1,CLK ' Use clock pulse to advance communication
' Null Bit
' SHIFTIN DOUT, CLK, 1, [DigBit\1] ' Actually grab the null bit
' Send a clock pulse to activate the null bit, but don't
' bother grabbing it
PULSOUT 1,A2Dclock
'DEBUG BIN1 DigBit, "-"
RETURN
' Get 9 OF 10 data bits using SHIFTIN
ReadData:
result = 0
SHIFTIN A2DdataO, A2Dclock, 0, [result\9]
HIGH A2Dcs ' Done with that reading. Pull CS pin high
RETURN
PrintData:
mVolts = result */ $139C ' x 19.6 (mv / unit)
DEBUG HOME
DEBUG "ADC..... ", DEC result, " ", CR
DEBUG "volts... ", DEC mVolts DIG 3, ".", DEC3 mVolts
PAUSE 100 ' delay between readings
RETURN
http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/MCP3202Demo.zip
I have been so used to digging in the deepest, darkest holes of the internet for code, I completely over looked what was right in front of me. Let me give this a shot and see what happens....
UPDATE:
The code ran fine and is WORLDS simpler than that beast I was messing with. However, I am still reading 5volts on both channels even when they are disconnected from a power source. Any more ideas? Or could I have managed to somehow smoke these 2 chips?
This sounds like a wiring issue.
Could you take a picture of your setup? It might help someone identify the problem.
To sum everything up:
1) Check the connections 600 or so times to be EXTRA sure!
2) Use the code Chris wrote as a starting point (http://www.parallax.com/Portals/0/Do...CP3202Demo.zip)
It's called the "smoke" test. You pray it doesn't smoke when you turn on the power.
