One of my chips: No propeller chip found on any serial port. Any hope?
ionymous
When I try to "Identify hardware..." with Propeller Tool, I get the error window:
"No propeller chip found on any serial port"
I have it wired up on a breadboard with the minimal setup, just power, reset, and tx/rx for the prop plug.
I've tried two other propeller chips in the same setup and they work fine. So I'm convinced it's just the one chip, not a breadboard, cable, or pc problem.
Is there anything I can try to revive my apparently bad chip?
But if this is a 40pin DIP package, you may have bent or broken pins on the corners and that might include the Pin 30 and 31. With a little tender care, you can either solder a salvaged pin over a broken or a bit of 20 gauge wire. Bent pins may be folded completely flat and never reach a socket.
I only had one Vss connected and one Vdd connected. I tried connecting both Vss and both Vdd but that didn't help.
I also tried connecting only "the other" Vss and Vdd pins (in case there was something wrong with the ones I normally use), but that didn't help.
BOE is grounded.
As for "bypass capacitors", I assume those are capacitors on my power circuit. Yes.
Out of curiosity, is there any pin on the chip that I could connect +3.3v and hurt it?
At this point I'm worried about how I hurt my chip, and I don't want to put a replacement chip into my more complex breadboard until I am sure I won't hurt another one.
2) You should not apply voltage (greater than 0V) to any pins before Vdd and Vss are connected to a proper power supply. This is true for almost any CMOS IC, not just the Propeller.
3) The most common reasons for a Propeller chip to be "Not Found" are: a) No power or improper power to the Propeller chip; b) Something wrong with the serial connection to pins 30 & 31.
I know there are a lot of schematics out there that abreviate the wiring... but that is the real wiring.
Reverse polarity is a sudden death contidion == +3.3 to ground and ground to the normal +3.3 supply.
9 Volts is a killer, I've tested one for that, and yes it had to be another chip.
The only times that I have had the "No Prop found ..." were due to the TX and RX paths being the wrong way around (using the PC's real serial port) or the attempt of using an AVR USB -> '232. That one I think had timing issues that the Prop wouldn't handle, a FTDI chip worked as expected.
