I gather from the parallax home page that there is now a real push for C for the prop? I wouldnt mind learning C but... would I be missing out on all that wonderful code in the OBEX ?
At the moment you cannot mix C and spin so you would not be able to use the current objects in the OBEX. There is some on going work to create similar objects in C, so that problem will go away or at least decrease. There is also a Spin to C translation program that seems to be working reasonably well. Using that may help you learn both C and Spin.
https://sites.google.com/site/propellergcc/documentation/tutorials/spin2cpp
Thanks. I thought it was very apropos to this forum when I first saw it.
