Stable Floating Point Calculations — Parallax Forums
KyeKye Posts: 2,200
edited 2013-06-19 17:53 in Propeller 1
So... lets say I want to do:
atan2(y, x)
Where x and y are doubles. How do I make sure that this function works for even small values of y or x?
I'm asking this question because I'm trying to display the phase information from the output of an FFT and I get round off errors that are making the phase plot look bad. At the frequency of interest the phase is zero but then goes crazy like random noise every where else. I believe this is do to the division of very small numbers by each other in the atan2 function.
  • ersmithersmith Posts: 6,286
    edited 2013-06-17 05:22
    Are you using a relatively recent version of propgcc? Also, are you using 32 bit or 64 bit floats? There was a bug in the 32 bit version of atan that was fixed last year but may still be in some releases. (Actually the bug was in the interface to the code; the code itself was fine, but the compiler was calling the wrong version of atan.)
    In general the math functions in propgcc are pretty stable -- they come from the OpenBSD math library, which in turn is based on Sun's fdlibm, which is very widely used.
    Eric
  • KyeKye Posts: 2,200
    edited 2013-06-17 07:48
    No, I'm not using propgcc for this. This is just a general C question.
    Apparently it is quite common to have this problem with making a spectrum analyzer.
    edited 2013-06-17 18:05
    Kye wrote: »
    It may depend on the compiler/library you're using. But in general handling floating point properly is hard (as you know!). I don't have any specific suggestions for atan2, I'm afraid, but you may be able to find some in "Numerical Recipes in C" or a similar numeric analysis book. Many university libraries will have some good resources like that.
    Eric
    edited 2013-06-19 17:12
    I took a class in numerical methods... unfortunately, multiplying or diving are considered safe. Its just the addition and subtract to worry about.
    Since I have no clue what atan2() is doing internally, this means I'm out of luck.
    There has to be some way people fix this however. Otherwise the phase of a sin wave is 0 at the frequency of interest and random noise everywhere else. Really confusing.
