Are Seeed Studio Shields compatible with BASIC Stamp 2?
I was in RadioShack today and saw Seeed Studio Shields that would be an awesome addition to my robot/general electronic. The shields are compatible with Arduino but I wanted to see if anybody knew whether or not the shields are compatible with the BS2.
There is no BS2 to "shield" adapter board.
There is a StampDuino board afterall.
They (Arduino) use SPI and I2C, but Stamps generally use asynchronous serial.
Much can depend on which "shield" you're talking about.
I think that overall you'll be investing a lot of time figuring out how they make it work and then trying to find if there's a way to make a Stamp improvise.
So, how good are you?
The Propeller ASC+ is compatible with Arduino Shields. You can you the BS2 Functions object from the OBEX to use many of the BS2 functions on the Propeller.
More info at:
http://mghdesigns.com/propeller/mgh-designs/propeller-asc-arduino-shield-compatible-1.html
http://www.parallax.com/Store/Microcontrollers/BASICStampDevelopmentBoards/tabid/137/ProductID/842/List/0/Default.aspx?SortField=ProductName,ProductName
But the BS2 doesn't have an A/D converter, so shields that require it won't work. Also as PJ Allen points out, I2C is common with some Arduino shields (e.g. compass, gyroscopes, real time clocks). The BS2 can do it via bit bashing, but it is a bit of a headache. So the answer is it depends upon the shield.
Well, there you go.
I had no idea.
Sold! I can use that with my Propeller ASC and Arduino library port.
Don't forget to send a buck or two for the twins' college fund...
12vdc into motor 1.0 board
Plug in the pins to homework board....and connect to pins 15....10
Common ground to 12vdc
