Spin Compile error: Expected a constant, unary operator, or "(". --> ???
I'm sure that this would be obvious to almost anyone else on here, but I keep running into this error, ( Expected a constant, unary operator, or "(". ), when attempting to use code in a format as shown below, that seems to me to make perfect sense, but is obviously poorly formatted in some way. I've placed the pertinent items of code below:
The line "StringSend(id, string("XTM-MAN........" works perfectly when I don't break the quotes to insert the variable "tankNum". When I do break the quotes to insert the variable, I get the above error.
I'm guessing that the code is interpreting the variable as a control character like the 10 & 13, rather than simply inserting the variable's value into the string that is sent.
Can someone give me some pointer into what understanding I am missing of how to handle this particular situation... what command in the Spin language reference I must have skipped over... :-)
Thanks!
Dave, struggling to drag myself into the world of the Propeller and Spin :-)
OBJ str : "StringMethods" 'StringMethods.spin ' ....... snip ....... PUB SendTestEmail(id) | size, tempMask, wait, stringPointer, tankNum ' ........ snip ........ repeat tankNum from 1 to 128 'Email body StringSend(id, string("XTM-MAN,", tankNum, ",Location Data,001,Product,06/16/2013 10:40:35,050.00", 13, 10)) pause(wait)
Thanks!
If you want to include variable information for display, you have to use methods like .DEC and .HEX. There are objects in the ObEx that help make this sort of thing easier for you like Numbers.
This compiles just fine anyway... now I'm going to actually send a test email with it and see if mu number increment accordingly.
Dave
Dave
StringSend(id, Num.ToStr(tankNum, Num#DEC))
This assumes that you have a declaration like this at the start of your program:
OBJ Num : "Numbers"
and you have to initialize this object once before calling any of the other routines in it:
Num.Init
Read the comments in Numbers for a detailed description of other formatting options.
XTM-MAN,´Äož,Location data,Product,06/16/2013 10:40:35,050.00
XTM-MAN,Äož,Location data,Product,06/16/2013 10:40:35,050.00
XTM-MAN,ož,Location data,Product,06/16/2013 10:40:35,050.00
I tried using the StringMethods ToString method:
And got this - but VERY slowly - it took over two minutes to send the email!
XTM-MAN,65535:,Location data,Product,06/16/2013 10:40:35,050.00
XTM-MAN,65535p,Location data,Product,06/16/2013 10:40:35,050.00
XTM-MAN,28725,Location data,Product,06/16/2013 10:40:35,050.00
XTM-MAN,53,Location data,Product,06/16/2013 10:40:35,050.00
I'll go grab Numbers and see what the difference is if I can figure it out. StringMethods uses assembler code which I haven't even started to try to wrap my head around yet... :-)
Interesting aside here - you say that my tankNum is being interpreted as a pointer to the data to send - so those numbers and odd characters are in memory somewhere at the "tankNum" address... is that how it's working?
Dave
I think I have an issue when it comes to using the OBEX. I don't seem to like just using code that works, unless I know HOW and WHY it works! :-) But I was always doing this with the Basic Stamp every time I used SHIFTIN/OUT or SERIN/OUT, etc - or DEBUG! I just never realized that I was using a sort of "built-in OBEX library" inside the Stamp. With the propeller, it's just more explicitly called - is my understanding of this correct? Which is why - in order to do simple Serial communication with the propeller, I can't just call SERIN or SEROUT unless I have explicitly included something like FullDuplexSerial.spin in my object declarations.
Slowly figuring this all out....
Thanks again!
Dave
