Help, can't solve this riddle.
Ikigai
I have a parallax demo board and a #28440 RFID module.
After flashing the EEPROM I can't connect to it with the PST at 19200.
Not even the error strings in the code are printed.
I'm going crazy over this, what am I doing wrong?
CON _clkmode = xtal1 + pll16x ' use crystal x 16 _xinfreq = 5_000_000 RFID_TX = 1 ' Connects to RFID R/W Module SIN RFID_RX = 2 ' Connects to RFID R/W Module SOUT obj Host : "FullDuplexSerial" RFID : "RFID.Reader.Writer.Driver" var byte TestBuffer[ 12 ] byte TestDataBuffer[ 32 * 4 ] byte OldPwdBuffer[ 4 ] byte NewPwdBuffer[ 4 ] byte HostDataBuffer[ 10 ] PUB TEST_THIS | ErrCheck, CmdByte, LoopCounter, IndexCounter, Offset {{ Test this driver }} ' start the host interface ( connected to PST ) ' ErrCheck := Host.Start( 29, 28, 0, 19200 ) if 0 == ErrCheck Host.str( string( "Cog Start Error", 13 ) ) else ' since host interface started, the next thing to do is to ' call the driver start method to start its I/O interface ' ErrCheck := RFID.Start( RFID_RX, RFID_TX ) if 0 == ErrCheck Host.str( string( "Cog Start Error", 13 ) ) ' if everything worked above, then enter terminal I/O loop ' if ErrCheck <> 0 Host.str( string( "Ready", 13 ) ) repeat
You'll see more of me seeing more questions will follow no doubt.
