Basic Stamp 2 Communication Problem
I've just built the OEM BS2 kit following the instructions verbatim. I powered it up with a clean 5V dedicated P.S. (Vss to ground and vdd to5V). I connected the DB9 to my PC serial port and couldn't establish a COM connection. Next I ordered "USB to Serial (RS232) Adapted" from Parallax, downloaded the drivers and then connect my PC to the OEM BS2. Again, I can not establish a COM connection. UGGHH!
Can someone (please) tell what I can do to troubleshoot this problem further?? Thanks!
And, welcome to the Forum!
Thanks for your time. You suggested a good thing to check. I did install them correctly. Anything else you can think of to check?
I am asking, to make sure you have a properly programmed BASIC Stamp Interpreter chip. Sometimes, people follow the OEM directions using an unprogrammed PIC chip, which won't work.
Anything getting warm/hot after powered is applied?
FYI - I've assembled two of these little guys with no issues, so you can rest assured that the product does work!
***ah! Ma'am Lindsay has brought up a great point! :thumb:
I bought this OEM Kit from Mouser Electronics. Where they bought it, I don't know. Perhaps you know? Here is a link to Mouser which may help:http://www.mouser.com/ProductDetail/Parallax/27291/?qs=%2fha2pyFaduhN6bcDCU7cVhMjWkcjZCzRqO72CmSIyec%3d
A PIC chip that is not "Programmed" is an interesting thought!
I did follow the kit build directions to the letter and I have more than 30 years soldering experience.
Here are a few other routine items you might rule out, before contacting Parallax Tech Support directly:
http://www.parallax.com/portals/0/help/BASICStamp/Connect/
I have just finished checking these items and found no problems. What about replacing the interpreter chip? Can I buy one from Parallax? What is the P/N? Thanks for your help!
Randyjp - any movement on this?
Curious in San Jose would like to know...
I'm waiting for an RMA# to send the module in to Paralax for repair.
Randy
