Propeller Tool - Multiple instances?
Hugh
Is it possible to have two instances of the Prop Tool open? I am working on sending data between two protoboards and having one version of the prop tool (associated to one board) on each of two monitors would be useful. I can't figure out how to do it - is it even possible?
I am using v1.3.2 on Win 7.
From the "Edit" menu select "Preferences". Select the "Files & Folders" Tab. Uncheck the "Associated files launch into single editor". Now when you double click on a Spin file it will open in a new instance of the Prop Tool.
Aha! Marvellous. Thank you.
