Old-School Instrumentation
In the time of analog gauges, long before MENU... SELECT... Back when men were men!
Here's a 360 panorama of the flight engineers station on a B-36: Six reciprocating R-4360s and four J-47 jets to keep an eye on, plus fuel, pressurization, hydraulics, electrical, and other systems.
http://www.nmusafvirtualtour.com/media/062/B-36J%20Engineer.html
Consider the guys who designed, built, maintained, and used these gauges before you complain about how complex your little project is!
That part over there with the tachometer and oil pulsator would be used by the flight engineer......
Corvair = 6 pistons
Corvette = a small, maneuverable, lightly armed warship, smaller than a frigate
http://www.wittelaw.com/personal/groupred/
My favorite factoid about the Sopwith Camel was that most versions didn't even have a throttle. The pilot would blip a switch (ie, BIT-BANG) to kill ignition to reduce power for landing.
The Gnome "mono" engines did not have throttles and were at full "throttle" while the ignition was on – they could be "throttled" with a selector switch which cut the ignition to some of the cylinders to reduce power for landing. The Clerget, Le Rhone and BR1 had throttles, although reducing power involved simultaneously adjusting the mixture and was not straightforward, so it became common during landing to "blip" the engine (turn the ignition off and on) using a control column-mounted ignition switch, the blip switch, to reduce power.
from http://en.wikipedia.org/wiki/Sopwith_Camel
Furthermore, since the SC fired bullets through the PROPELLER, the proper BAUD RATE and STOP BITS were required to synchronize with the machine gun.
You forgot the single most interesting thing (IMO) about the Sopwith Camel, it used a rotary engine - that is the propeller was mounted directly to the engine and the crankshaft was bolted to the firewall. The gyroscopic forces from the spinning engine made for very quick turns to the right, slow turns to the left.
My first job was at Pratt Whitney Aircraft Engines in West Palm Beach Florida. They had a long, proud heritage of their WASP radial (not rotary) engines, including this 28 cylinder, 56-sparkplug beast: http://en.wikipedia.org/wiki/Pratt_%26_Whitney_R-4360
Don't foul all 56 plugs on startup!
From wikipedia:
"....The B-36 had a crew of 15. As in the B-29, the pressurized flight deck and crew compartment were linked to the rear compartment by a pressurized tunnel through the bomb bay. In the B-36, one rode through the tunnel on a wheeled trolley, by pulling oneself on a rope. The rear compartment featured six bunks and a dining galley, and led to the tail turret...."
http://en.wikipedia.org/wiki/B-36
