WIZnet Ethernet Board for Quick Start does not run on external power.
Alarus
But when powered from USB works fine.
In what may be the Problem??
/USB_PWR_EN connected via a divider to the FT232RL on the QuickStart board.
Yes I use the QuickStart board + W5200 board for QuickStart. I connect the external power via jack on the W5200 board.
1) Is the program loaded into EEPROM?
2) Are you using the Parallax Serial Terminal to view debug information. If so, using the following PST initialization code block.
if(ina[USB_Rx] == 0) '' Check to see if USB port is powered outa[USB_Tx] := 0 '' Force Propeller Tx line LOW if USB not connected else '' Initialize normal serial communication to the PC here pst.Start(115_200) '' http://forums.parallax.com/showthread.php?135067-Serial-Quirk&p=1043169&viewfull=1#post1043169 pause(500)I can assure you the WIZnet Ethernet Board for Quick Start does run on external power.
Yes, in the initialization block is the code.
I load the standard example WebServer_W5200_RTC.spin.
It works fine with powered USB, but with external power supply there is not any reaction.
I'm not saying that the board W5200 does not work, I'm trying to understand the reason why is not working.
WebServer_W5200_RTC.spin program does not work in the examples from external power.
I'll have to consider using a debug flag to turn off the pst debug terminal.
