PASM Labels Used in Called Methods
Hi All;
In a Spin program, is there a better way to access the PASM labels of an object's methods other than using the "object#constant" reference procedure ?
In the Spin program, I wish to know the cog address of PASM labels of a ch routine, and find having to manually redefine a set of constants in the assembler program as the label address move around while I debug it to be a real pain.
Perhaps there is a trick I am unaware of.
Cheers,
Peter (pjv)
Cheers,
Peter (pjv)
DAT org 0 enter mov 0,0 mov 0,0 label mov 0,0 mov 0,0 mov 0,0 'PASM address of lable label_ long (@label - @enter) / 4What does "PASM labels of an object's methods" mean?. As far as I know methods don't have PASM labels what with not being PASM code.
Kuroneko, how do you (automatically) generate such a table ?
Heater, I have a Spin program that wants to call one of several assembly methods in an object, using a common PUB to access them. The compiler knows the addresses of these entry points, but won't let me use their names in the parent that's calling them. Hence so far I'm obliged to use the 'object # constant' procedure to effect what I'm trying to do. And during debugging that is a real pain because the addresses all keep changing.
It would seem to me to be a real benefit if constants could be allowed to inherit the address value of a PASM label. And while we're at it, to allow constants to have global assignments across all objects.
Cheers,
Peter (pjv)
DAT ' translation table __table word (@__names - @__table)/2 word set_scrn, set_font word set_crs0, set_crs1 word set_plte, set_bgnd word res_x word res_y __names byte "scrn", 0, "font", 0 byte "crs0", 0, "crs1", 0 byte "plte", 0, "bgnd", 0 byte "res_x", 0 byte "res_y", 0The first six entries are code entries from a PASM section in the same file, the last two just constants which identify the screen size. This table (in my case) is referenced from the binary header and some SPIN code extracts the relevant bits (see [thread=139112]DDK example[/thread]).Phi...., I have done that, but it makes for a further level of indirection, increasing size and dropping performance. This is for use in my OS, and I want it to be as tight and responsive as I can get it. The assembler knows the addresses, so why not let them be used directly in the program's CONstant definition block.
Marko.... I'll try your suggestion while I'm debugging.
Cheers,
Peter (pjv)
