Question about RS232 to USB adaptor — Parallax Forums
Don MDon M Posts: 1,654
edited 2013-06-07 17:48 in General Discussion
I am looking for an adaptor to convert an RS232 D9 pin to USB. I know there are tons of USB to RS232 adaptors but will these work in reverse? Anyone have a source for such a thing?
Thanks.
Don
  • Don MDon M Posts: 1,654
    edited 2013-06-07 13:06
    Essentially it would be a RS232 to USB host adaptor.
    edited 2013-06-07 13:38
    Don M wrote: »
    You didn't say what gender, but Parallax sells a Male to USB connector. Is that what you are looking for?
    Congrats on hitting 1000 Posts!
    Jim
    edited 2013-06-07 13:55
    Thanks for the congrats!
    That adaptor is the opposite of what I need. I need to go from RS232 to host USB.
    In searching around it doesn't look like there is an off the shelf solution. I spoke with FTDI and they have a solution but it would require me to make a board to make and adaptor.
    I have an application where I want to go from an exsiting DB9 port on a PLC to one of my devices that has a USB connection. It looks like either way I'll have to kluge something together.
    edited 2013-06-07 17:11
    What you want is a USB host and for that you'll need a microcontroller. There's a Propeller stack that might work depending on what USB device you have. Look in the ObEx for the object and its features. Another option would be to use a memory stick datalogger and some microcontroller.
  • GenetixGenetix Posts: 1,777
    I don't whether you are working with the older square end cables or the newer mini connectors but I have seen adapters for connecting to square end or Type-B connectors together.
