X10, Trigger Mode, and a Request
I recently received a PropScope for testing. I have 2 questions and a request for the software. 1) When I set both probes to the X10 setting in the Tools menu, only Channel 1 properly shows the correct voltages. Channel 2 still shows the X1 values. 2) I am trying to perform a single capture when an event happens. This appears to be the "Step" function in the Trigger menu, but this does not wait for a pulse to capture. It just captures a flat line. Am I doing this incorrectly, or doesn't a "single" mode exist? 3) It would be beneficial to have a Save/Load configuration feature with the probe, dial, and trigger settings so I don't have to keep changing values between common measurements. Is this a possibility? Thanks, Dan
I'm the author of the PropScope software. I apologize that I didn't see your post before today. Best
way to contact me is directly via email: hsander at gmail dot com.
Here finally some answers:
1) I started up PropScope and connected both probes to a 5V signal. I set the switch on both probes from 1X to 10X. I clicked on the "Tools" menu, selected "Manage Probes" and entered "10" for both probes. I've attached the result- everything looks fine to me.
Is it possible that you didn't set the probe switch to the 10x setting?
2) I started up PropScope and set the trigger mode to step. I also set the trigger level (the yellow indicator on the left) to a non-zero value- in my case 1.7V. I then clicked on the circle next to the trigger "step" to start looking for the trigger condition. The graph then indicates "waiting for trigger". Finally, I touched the probe to my 5V signal which caused the probe to acquire the signal and then pause. The attached graph shows the signal both before and after the trigger condition.
I assume you didn't set your trigger level from the default value of 0V- which would cause the trigger to fire when the signal was at 0V.
3) I'm quite busy with other projects but I'll add your suggestion as a possible future enhancement.
Hanno
This is what I get with 2.0.5. with both probes set to x10 and software set to x10
Screen shot:
Had not noticed before, but I am able to replicate it every time.
Thanks Publison for the independent test- looks like I'll have to dig a bit. Were you able to replicate the trigger issue?
Hanno
Hanno,
I'll check the trigger issue tomorrow and report back.
Hope you have been earthquake free for a while.
Jim
I've figured out the problem- I tested on a machine running v2.03 where the probe scaling worked. In v2.05 I see the issue you're seeing. I've verified that the triggering works as intended.
H
Also verified trigger is working fine in Version 2.05
http://forums.parallax.com/showthread.php/123627-Latest-PropScope-software
