Rfid reader anti-collision
Hi.,
i am going to use the nRF24L01+ Transceiver as RFID READER and RFID TAG.
But now i am going to implement the ANTI-COLLISIION method for this IC .
Can you please suggest me some model code to support this Transceiver IC?
thanks in advance .,
janu
janu
as i am going to use nRF24L01as transmiter (RFID TAG) and nRF24L01 IC as RECEIVER(READER) also . But i need implement the ANTI-COLLISION code along this transceiver firmware . So can you please provide some ANTI-COLLISION model code for supporting this IC.
Thanks in advance
The sequence could be something like:
1. RFID reader listens for transmitted packets.
2. RFID tag listens for no RF data transmission and sends data packet (tag id, checksum, etc.).
3. RFID reader verifies received data (tag id, checksum, etc.) is valid.
4. if data is valid RFID reader sends ack packet (ack, tag id, etc.).
5. if data is not valid RFID reader sends nak packet (nak)
6. if RFID tag receives nak packet it waits for a random length of time and repeats from step 2
Or it could be:
1. RFID reader sends stx packet (stx) and listens for a response for x mS.
2. RFID tag listens for stx packet.
3. RFID tag waits for a random length of time that is less than x mS
4. if no other data is being sent RFID tag sends data (tag id, checksum, etc.).
5. if data is valid RFID reader sends ack packet (ack, tag id, etc.).
6. if data is not valid RFID reader sends nak packet (nak)
7. if RFID tag receives nak repeat from step 2
Thanks for your great support.
If the single Tag(nRF24L01 TRNSMITTER) communicate with mulitple reader(nRD24L01 RECEIVER),then all readers will get confused to receive the response from which TAG.
This stage the collision occurs,am ryte. so we try to avoid this collisions using anti-collision method.
Short of having a token passing or master slave system there is no way to avoid collisions completely. A system that detects collisions and has the senders back off for a random length of time before resending data is generally how bus and RF systems are done.
What type of system do you want to build?
It sounds like you want to have multiple readers and multiple tags within range of each other. This type of system will be the most difficult one to write software for, and would probably require some form of token passing.
A single reader that can read a single tag is the simplest system, and is pretty much equivalent to the standard RFID tag/reader systems in general use.
There are several possible systems between these two choices.
Usually when people want to build a wireless network, they buy ready-made devices that handle the end-to-end protocols needed like xBee. Other than very general discussions, I'm afraid that we can't really help you. The sample code provided for the transceiver just does CRC error checking for a single pair of transceivers. Anything more complex is something you'll have to research and develop on your own.
I have added questions to the flow diagram you posted. I was asking for more information regarding the overall project rather than details of how a single device operates. It sounds like you plan on having multiple devices like the biocrypt scanner that send the authentication tokens via RF to a reader, which then passes it on to the server by RF or a wired connection. The server response is then sent back to the device by the same path. This is the part you need to explain clearly to get any help.
Thanks for your reply.I replied your questions in this attachment.Please refer this.Let me know did you having any questions.Thank you..
Best Regards.,
Janu.
Since this is a system with tags and readers in fixed positions, assign each tag to a specific reader.
Have the server or an intermediate microcontroller poll each reader in turn. When the reader is polled it in turn polls each tag, and the tag sends ETX if there is no data, or it's data followed by an ETX.
Features are going to be implement with the Active Tags:
- I want to send data(information) to the Receiver from the Tag .
- Receiver want to know there is a Tag in Range.
- Only Ack feedback must be transmit to TAG from the RECEIVER.
- APPROXIMATELY - 20 Tag will get communicate with the SINGLE Receiver.
And My question is:- If the single Tag communicate with multiple reader,then all readers will get confused to receive the response from which TAG.This stage the collision occurs,so we try to avoid this collisions using anti-collision method.
Thanks and Regards.,Janu
