FullDuplexSerial: bit of a head-scratcher re: rxcheck
Mickster
I have a very simple loop where I am transmitting data to my Android device via RS232 and a Bluetooth adapter.
Although not currently receiving data, I have provided for it and it works very well, the following is in the same loop:
The problem is that when I disconnect the bluetooth link, using the menu selection "Disconnect" on my Android device, the Propeller programs stops looping.
If I remove the above ".rxcheck", the lockup doesn't occur, the Propeller program continues to loop and when I re-establish the BT connection using the menu selection "Connect" on my Android device, the Android program resumes receiving the transmitted data from the Prop.
Clearly something is upsetting the .rxcheck routine but the comments state that:
Any ideas would be appreciated.
Mickster
Case MC_Com.rxcheck
-1:
"A":
"B":
"C":
etc., etc.
'' Check if byte received (never waits)
'' rxbyte returns -1 if no byte received, $00..$FF if byte
Mickster
Some bluetooth modules send out characters when a connection status changes (ie, a status message). Maybe these characters are interfering with your routine?
Why not insert some debug code to transmit via your prop plug to Parallax serial terminal (PST)?
You could start with adding other: to the case statement and tx out to the PST....
Is this the code for my board? I'll be happy to help if you set me up with the android app I have a couple of Bluetooth adapters.
Coely
So the following DOES keep running, no matter what....let me include the other stuff, a bit at a time and I'll post the code that crashes.
CON _clkmode = xtal1 + pll16x _clkfreq = 80_000_000 RS232RX_2 = 24 RS232TX_2 = 25 LED_1 = 27 ' LED 1 LED_2 = 26 ' LED 2 Mode = 00 Baud = 19200 BT_TimeOut = 1000000 VAR long Scheduler,CntMem,BT_WatchDog byte GetOut,MainStop OBJ MC_Com : "FullDuplexSerial" PUB Start | char , rxchar, starttime, endtime MC_Com.Start(RS232RX_2,RS232TX_2,Mode,Baud) 'Term.rxflush MC_Com.rxflush DIRA[LED_1..LED_2]~~ ' Set LED1 and LED2 to be outputs OUTA[LED_1..LED_2] := ' Turn on LED1 Repeat 10 !OUTA[LED_1..LED_2] ' Flash LED1 and LED alternately 10 times waitcnt(cnt+clkfreq/30) OUTA[LED_1..LED_2]~ ' Turn off both LED's Scheduler:=0 MainStop:=0 Repeat until MainStop Scheduler++ Case Scheduler 500: 3500:!Outa[Led_1] 3600:Scheduler:=0 ++BT_WatchDog BT_WatchDog<#=BT_TimeOut MC_Com.str(String("DATA")) MC_Com.dec(BT_WatchDog) MC_Com.str(String(";")) Case MC_Com.rxcheck -1: "A": "B": "C": "X": MainStop:=1 Other:MC_Com.tx("?")Thanks guys.
Mickster
P.S. I already suspected that I could be getting a random "X" character which would also kill the loop but I already ruled this out.
As you can see, if the characters A or B or C (it actually keeps going through to H) appear then "GetBendData" is called. My current testing involves receiving nothing so this routine is never called. However, when I break the bluetooth link, "GetBendData" gets called and the hangup occurs because that next repeat loop won't quit until a ";" is received.
If I REM-out all of the calls to GetBendData, I can connect and disconnect without problems but if I un-REM ANY of the GetBendData calls, the program will call it when I disconnect the BT communication.
Case MC_Com.rxcheck -1: "A": GetBendData Bend[0]:=BendData MC_Com.dec(Bend[0]) "B": 'GetBendData Bend[1]:=BendData MC_Com.dec(Bend[1]) "C": 'GetBendData Bend[2]:=BendData MC_Com.dec(Bend[2]) PRI GetBendData BendData := 0 GetOut := 0 waitcnt(clkfreq/500+cnt) repeat until GetOut == 1 case MC_Com.rxcheck "0": BendData := BendData * 10 "1": BendData := BendData * 10 + 1 "2": BendData := BendData * 10 + 2 "3": BendData := BendData * 10 + 3 "4": BendData := BendData * 10 + 4 "5": BendData := BendData * 10 + 5 "6": BendData := BendData * 10 + 6 "7": BendData := BendData * 10 + 7 "8": BendData := BendData * 10 + 8 "9": BendData := BendData * 10 + 9 ";": GetOut := 1I will experiment further.
Mickster
Just so happens that they coincide with my Case conditions...DOH!, DOH!, DOH!
I'll get me coat :-)
Mickster
