StampPlot Lite or Pro for Window 7 & 8 — Parallax Forums
GenetixGenetix Posts: 1,777
edited 2013-10-01 08:59 in Learn with BlocklyProp
Several of the Stamp-in-Class manuals, such as What's a Microcontroller, say to use StampPlot Lite (1.7) which was written after Windows XP was released. My new computer has Windows 7 and other people are using Windows 8. I know the last version StampPlot Pro (3.85) was created after Windows 7 was released so should I be using this version instead of Lite? And what about StampPlot Pro 3.75 which is on the Parallax website?
  • Martin HebelMartin Hebel Posts: 1,239
    edited 2013-06-05 20:07
    I'll do some testing and give you the best recommendation early next week.
    Martin
    SelmaWare Solutions
  • GenetixGenetix Posts: 1,777
    edited 2013-06-06 07:01
    Thanks Martin.
    edited 2013-06-10 09:45
    - With WAM, StampPlot Lite should still be used. StampPlot Pro is compatible, but not so quick and easy to use for what WAM covers. WAM 3.0 only give passing reference to the software in any case.
    Lite may be found here:
    http://www.parallax.com/tabid/441/default.aspx
    - As to Process Control text and StampPlot Pro, version 3.75 has issues with post-XP OS's. Version 3.85 should be used and can be downloaded here:
    http://www.stampplot.com/downloads/stampplot_v3_rel85.exe
    I've asked Parallax staff to update their version.
    The only problem appears to be the SIC Process Control Macros will not open by association (double-clicking the SP macro does not load it into StampPlot). For the user to open the installed macros they must:
    1) Open StampPlot Manually
    2) Select the "Macro" menu item, "Run Macro", and locate the desired macro file manually in Desktop\SIC Process Control
    Other than that, all appears to operate correctly.
    Thanks, hope this helps,
    Martin Hebel
    SelmaWare Solutions
    edited 2013-06-10 12:54
    Martin Hebel
    SelmaWare Solutions
    Thanks for clarifying that. Can I install both programs on the same computer or should I use Lite first and then switch to Pro later?
    Brian
    edited 2013-06-11 05:47
    Yes, they may be installed at the same time.
    Martin
    edited 2013-06-11 13:36
    Martin
    Great! Thanks Martin for the help.
    edited 2013-06-20 12:55
    Martin, I noticed that I have StampPlot Pro V3_Rel92 which is no longer available for download buried within my Parallax folder. Wasn't this a beta version or can I use it?
  • doppler5756doppler5756 Posts: 1
    I'm having a related issue. I'm in a Control Systems class and we all had the problem above until we figured out we needed to run the macro manually. However, now I'm having a problem with Stampplot and Activity 4-6 in the Process Control Text. Basically, we're supposed to run Tachometer.bs and the sic_pc_gen_process.spm macro. However, after doing so, running the macro, and connecting in Stampplot... nothing happens. There's a bunch of labels/parameters in Tachometer.bs (see below) that are supposed to be getting passed to Stampplot but none of that changes in Stampplot either. It's like the macro doesn't work. I'm running Windows 7. I've tried to see which point the program gets hung up and it appears it doesn't even complete the 1st subroutine (ReadSP) in the Main routine. It doesn't complete the line in that section: DEBUGIN DEC SP_Data. I don't know what's going on with this macro... everything in Activity 4-1 and Challenge 4-1 worked fine. However, this does appear to the be the first code that's passing labels to Stampplot.
    [ Initialization ]
    PAUSE 500 ' Connection stabilizing time
    DEBUG CR,"!RSET",CR, ' Reset StampPlot
    "!CLRC",CR, ' Clear any text on plot
    "!SPAN 0,10000",CR ' Set Y-Axis span
    ' Label text boxes
    DEBUG "!O lblData = Sample Time\n (mSec)", CR,
    "!O txtData = 1000", CR,
    "!O txtR = ", CR,
    "!O txtY = ", CR,
    "!O txtG = Sampled", CR,
    "!O Stat1 = Counts:", CR,
    "!O Stat2 = RPM:", CR,
    "!O txtFileName = Tach1", CR
    DEBUG "!O Meter = 0,0,10000,0,10000", CR ' Set SP meter
    DEBUG "!RSET", CR ' Reset after configuring
    LOW Sampled
    1024 x 605 - 89K
    4-6.jpg 88.7K
