New improvement
hi all,
my name is Anass, i'm process technician working with SEWS-E.
i want your help for an improvement
, so :
all my tasks have relation with Machines " KOMAX" , machine produce wires for CARS and other stuffs...,
so if an operator has a problem with the machine , must call the maintenance...
at level of the machine there is a box with toggle button .. linked to lamps...
green one = mention that the machine produce wires
bleu one = mention that the operator needs maintenance
Orange one = operator needs Quality service
red one = mention that the machine stopped
attached shows you how?
so the improvement is to change the box with toggle buttons to an application set on the machine screen... you know! we want to change something physic to something logic!
like an application gives you the possiblity to switch off and switch on the lamps ...
the question is : what i need to realise that ?
thaaaaaaank you in advance
The system you have at present is quite simple and reliable.
Other than trying to automate the level of help required by detecting what stopped the machine, you could duplicate the existing functions with the PLC that controls the machine itself. You would add the buttons to spare inputs and use some spare outputs to turn the lights on and off. If there is an operator interface touchscreen, you could also move the help buttons to that screen.
If you can give more details of your desired result, we may be able to offer additional suggestions.
Cheers,
for more informations, Machine KOMAX works under windows XP Embedded ,
i want to know if there is an USB connection ?
thanks again for your collaboration Mike
Is there some overwhelmingly important function that the current system does not provide that justifies making it more unreliable?
sorry if i'm bothering .. my last question...
please to describe to me all what i need? i mean all materiels and stuffs like this ?
i'm so sorry man ... really it's nice from you
You'll need a proper case and mounting hardware. You'll need a USB cable. You'll need wire to connect the Prop-1 to the relays. You'll need some kind of power supply that depends partly on what relays you use. I can't tell you what relays you'll need without more information about the lamps. There may be electrical requirements that I don't know. There may be mechanical requirements. There may be electrical noise issues that require filtering of the power source and maybe shielding of the electronics and I can't begin to guess any of this. I don't know where you're located, but there are probably other local, regional, and national requirements for controlling industrial equipment.
