Problem with serout in BS2p40
Hello.
I succeeded communicating a bs2 with a gprs module via serial with serin and serout commands.
But now i need to do the same with a bs2p40 module. I've changed the current baud rate config but the gsm module doesn't answer it.
I entered both signals into an oscilloscope, they both have the same form but 2p40 signal has 0.5 milliseconds longer. i don't know if it's enough to miss the data.
if anyone knows why can be this happening please answer
Thanks!!
Thanks!!
This is a very simple example but its enough to watch:
BS2P program:
2p40.bsp
BS2P Signal:
2V x Div / 2mS x Div 1V x Div / 2ms x Div
BS2 program:
bs2.bs2
BS2 Signal:
When i send
SEROUT 0,813,["AT+SHDN",CR]
with BS2; the gprs module is shutted down like it should be.
but when i send
SEROUT 0,2063,["AT+SHDN",CR]
with BS2P; the module it's not responding.
if there´s anything else that can help you please let me know
I've solved the problem...if you look at the graphics the BS2 sends a 5,2 Volts Pulse Train while the BS2p sends only 4.8V. Those 0.4 Volts were enough for the non responding module.
I've put a 2N2222 Transistor to increase Voltage.
Thanks a lot Mike and Zoot for your concern.
