Is there any documents for learning how to use the Prop with a quick start
gennarobasso81
hello, I never used a propeller chip before and bought the quick start board. I am looking for some things to learn on. Is there any thing good to read for this board? I have already downloaded and started to read the PE Kit manual. thank you
http://code.google.com/p/propforth/
It is forth, not the spin language for the most part, but will get you familliar with the interesting parts of the prop quickly.
After you get the command line going by loading the kernel, try the quickstart touch button demo, the software logic analyzer, and ASCII escape codes packages. From there you can built the LittleRobot for under $20
http://www.parallaxsemiconductor.com/quickstart
