PropFORTH load error: chip lost on COM 16
Iamretired
I am trying to compile and load 'DevKernal.spin" of PropFORTH 5.5. These steps were followed:
Prop is 'there' but it is lost?
I followed the PropFORTH install instructions ( I think ), but came up with an error.
- Loaded DevKernal. spin from CurrentRelease\PropForth
- Identify Hardware: Propeller chip Version 1 found on COM 16
- Compile Current/ Load EEPROM
- Loading Ram
- Verifying Ram
- ERROR: Propeller Chip Lost on COM 16
- Identify Hardwaree: Propeller chip Version 1 found on COM 16
Once you can load any spin file, the kernals (devkernel.spin) always work.
I downloaded Propeller Tool 1.3.2 and tried loading Tachyon again, but got same error.
Should I post this somewhere else if it is a prop tool problem?
Thank you for your responses.
John
For Tachyon questions best talk to Peter Jakaki, the author; he's on these forums.
For Propforth issues, please talk to me.
Can you load ANY spin program? If you can load any spin program, then propforth will also load. If you cannot load another spin program, we can diagnose your set up.
Typically, this indicates a power supply issue, but I'm talking from anecdotes, not from experience with you board. Can you verify voltage and current?
At the point you are having problems, PropForth and Tachyon are simply Spin programs. Any loading issues are not related to it being a Forth, just a Spin program. You should have the same issues with any other large Spin programs you try and load.
The Activity Board should take power from your USB connection, so that shouldn't be an issue (again, try different USB ports and cables).
Thanks to each you who had suggestions. You make this forum great!
Johnmb
The prop is detected, so everything looks fine.
Loading to ram should be no problem (by the way Forths should be loaded to eeprom).
Could be a power supply issue?
Massimo
Edit: did you try a different cable, ane possibly pc?
I have run several programs using USB power without a problem on both boards..
I have used two USB cables on two different ports: com16 and com2
The error occurs during Ram Verify at about the same point of the verify.
John
I want to capture the exact nature of your questions, so I can put the question and the answer in the instructions.
I run PropForth and FemtoBasic from TeraTerm terminal.
When loading the Spin code using PropTool I get the same error if I forget to disconnect the com port in TeraTerm.
Essentially there is a conflict with the two programs using the same com port.
Just disconnect the com port in the terminal and PropTool is happy.
Just a thought!
Duane J
Also, if you are using a virtual machine to run windows, you have to specifically grant permission to the virtual machine each time you re-plug the USB.
One more thing I noticed recently: On a very slow machine, I was ripping a disk with Handbrake in the background, and Proptool could not program the Quickstart. I guess there wasn't enough CPU power, even though Handbrake is supposed to be n the backgroup, and the proptool is supposed to be in the foreground. After Handbrake finished, Proptool programmed the quickstart normally.
Turns out there were several USB devices that are sometimes noticed not to play well with others. After disconnecting the printer, scanner, and some thrird device, the PropTool was able to successfully program the kernel into the prop EEprom. After the PC was rebooted, Teraterm 3.1 was found unable to use 230400 baud.
Teraterm 4.71 (?) was able to connect at 230400, everything looks fine now.
He was able to locate propforth.htm, and started reading section 3. I advised finish reading section 3 before going to the Brody books, as section 3 points out many of propforth's commands that might be different from a workstation forth typically used with those references.
Thank you for getting me started.
John
