Differences between Propeller Activity Board @ Prop. Board of Education? — Parallax Forums
banjobanjo Posts: 483
edited 2013-06-03 11:01 in Propeller 1
So, what's the main differences between Propeller Activity Board @ Prop. Board of Education?
Apart from the price obviously.
I have a Stamp BoeBot, could I replace that board with one of the Prop. boards?
  • JonnyMacJonnyMac Posts: 9,653
    edited 2013-05-31 10:40
    The Activity Board is a great Boe-Bot replacement. It doesn't have the AV stuff that is on the Prop-BOE -- these things are not used a lot, and certainly not very helpful on most robots.
  • banjobanjo Posts: 483
    edited 2013-06-01 11:04
    Thanks Jon for the clarification!
    Will probably upgrade to the Activity board when I hit the wall with my BS2.
    edited 2013-06-01 11:47
    Let me suggest that when you make the switch to the Propeller you go full-tilt-boogie and learn Spin (or Propeller C is that's your choice). Many choose to restrict themselves to BS2 functionality by using an object that gives you those features -- but, in my opinion, it holds you back, too. If you just accept the Propeller for what it is and go for it, you can have a really great time. It takes just a little effort to get used to the idea of multiple processors working together, but once that idea latches, you'll wonder why it isn't the "norm."
    edited 2013-06-03 01:02
    Yep, either Spin or Prop C I'll for sure use. Have some decades of programming experience with different languages (anyone remembers Logo, Cobol, Pascal...) so the programming language is typically not that a big issue for me. On the electronic side I'm however a newbie.
  • Steph LindsaySteph Lindsay Posts: 767
    edited 2013-06-03 09:12
    Here are some specific differences:
    • The Propeller Board of Education includes a microphone, a VGA connector, and a bank of 8 LEDs (inline with other peripherals).
    • The Propeller Board of Education has a much beefier 5 V switching voltage regulator that can deliver up to 3 A. The Propeller Activity Board's linear 5 V regulator tops out at 1.5 A max.
    • The two boards use different ADC converter ICs. So, at the moment, code examples using the ADC that work for one board will not work for the other.
    • Both boards include an XBee header, but the Propeller Board of Education gives you access to more of the XBee pins.
    I hope this helps!
    Thanks Steph, this for sure helps
